06 Muffler
Old Jan 19, 2006 | 07:56 PM
Turbinator's Avatar
06 Muffler
My dad wants something to let his truck breathe a lil bit. Would the muffler that came with my Magnaflow 4" exhaust be worth putting on there?
Old Jan 19, 2006 | 07:59 PM
Herrin811's Avatar
anything is better than stock
Old Jan 19, 2006 | 08:04 PM
Turbinator's Avatar
Herrin821, any noticeable difference in performance/mileage w/ your BHAF & MBRP Muffler?
Old Jan 19, 2006 | 09:29 PM
04ctd's Avatar
if it's straight, it will offset the tip under the bed a bit, and make it resonate.
grab a "3A racing" 4 to 5 inch tip at Pep Boys for $42, and that should get it out past the bed.
but yes, it should work great.
Old Jan 19, 2006 | 09:50 PM
smokin05's Avatar
man your not kidding about the bed making noise after you straight pipe it....I have got to do something my truck vibrates like crazy...my buddy just got a leftover 05 and its still stock...I could not believe my truck was once that quite!
Old Jan 20, 2006 | 02:36 PM
Mark Craig's Avatar
roan,
Take a look at the MBRP replacement muffler, it has welded hangers and an S pipe to make the factory pipes line up correctly instead of angling the muffler liek you wree asking about on the Magnaflow. Check and see if he has a resonator just after the muffler on the stock system. If he doesn't then the MBRP muffler will bolt right on, if he does have the resonator he'll have to bend the welded hangers on the MBRP replacement muffler to compensate for the change in the resonator location etc. Sounds great and if he keeps the factory cat keeps the volume way down except when he flat foots the go pedal!
Mark @ DPPI
Old Jan 20, 2006 | 03:14 PM
Turbinator's Avatar
Thanks Y'all
Old Jan 20, 2006 | 08:31 PM
rjm022's Avatar
donaldson 41' muffler!
Old Jan 20, 2006 | 08:40 PM
04ctd's Avatar
that Tip from Pep Boys (or any tip) should fix you right up.
one local parts shop sells hollow 2.5 inch to 4 inch tips, you could just cut the end off, and slip it on.
timk006
Oct 13, 2006 03:49 PM
Jmac
Sep 9, 2006 10:23 PM
Patrick Campbell
Mar 23, 2005 01:29 PM
commonrail
Oct 22, 2004 07:47 PM
w4xtc
24
May 5, 2003 04:36 PM
