03 Mod Help
Old Oct 24, 2010 | 12:46 PM
MOverton's Avatar
03 Mod Help
I just purscased a 2003 QC 4x4 with AT (48RE) with 70,000 miles. It is currently stock. I would to do some mods to upgrade pulling capability and fuel mileage but not enough where I have to spend alot of money on the transmission.
I currently use the truck as daily commuter and use it on the weekend to pull a bobcat, 70hp tractor, or a dump trailer.
Any suggestions are appreciated. Thank You.
Old Oct 24, 2010 | 01:36 PM
MTC's Avatar
MTC
Spend some time reading over all the posts here and you will get some good ideas as to what you need to do.
For what you are explaining above, I would say intake (homemade or store bought), exhaust (straight pipe?), and a Smarty Jr. I would also say a good set of guages to keep track of it all.
Old Oct 24, 2010 | 04:31 PM
rockcrawler304's Avatar
MTC is correct. You will need to be careful of any additional power. You can run the Smarty Jr on the tow setting but just be easy on the takeoffs!
Old Oct 25, 2010 | 03:43 PM
ropnjessi's Avatar
It seems anything over 70hp added over stock you are looking at tranny upgrades, so maybe this is a starting or end point for you.
Old Oct 25, 2010 | 04:54 PM
moorepower's Avatar
Get a he351 turbo off of a .4.5 and up truck, for more air. Mod your own air box. All you need is a muffler, you will see little in a 4" exhaust. I have a Smarty, but a Quad box on about 50 h.p. is a lot better than stock.
Old Oct 30, 2010 | 04:57 PM
MOverton's Avatar
I read about moding you existing air box but haven't had any luck finding a thread on how to. Can anyone point me in the right direction. Thank You.
Old Oct 31, 2010 | 08:40 AM
diablo1's Avatar
Does anyone have a link tho the 04.5 turbo mod.
Thanks
Old Oct 31, 2010 | 11:31 AM
Dodgezilla's Avatar
You don't need a link. If you can pull your turbo off your truck then you just do that and replace it with the newer turbo. Install an adjustable boost elbow or simply clamp the wastegate hose off. That's about it unless you want to also get the better 04.5+ exhaust elbow and a real 4" downpipe...
As far as what the OP is looking for. Just do everything in my sig. I had the same plan for my truck that you have and it's perfect now.....
Old Oct 31, 2010 | 04:40 PM
moorepower's Avatar
Look under Home Depot intake. You cut a 4" round hole in the bottom of the filter housing, hook up a piece of 4" drain hose and run it down below the engine compartment. Then use a 6.7 air filter. There are two large threads on the he351 turbo. It is a true bolt on. The quad box will give you all the power your trans can hold. Add a free flow muffler, if desired as the gains seem to be less than 10 h.p. and you will add 50-75 h.p. and the drive ability will be much better. If you do a little shopping around, this can be done for under $500.
Old Nov 2, 2010 | 08:47 PM
MOverton's Avatar
From reading on the site and this thread, I believe I have a plan.
Gauges (Boost, Pyro, Trans)
Home depot intake
smarty jr
Is there anything wrong with running the stock exhaust?
Old Nov 3, 2010 | 05:05 PM
moorepower's Avatar
Nothing wrong with stock exhaust. I would look for a he351 down the road.
Old Nov 3, 2010 | 09:38 PM
MOverton's Avatar
Will add the he351 and the smarty exceed the auto trans?
Old Nov 4, 2010 | 09:36 AM
MTC's Avatar
MTC
Just the Smarty jr will exceed the tranny...I have slipped mine a couple times just trying the upper settings
Old Nov 4, 2010 | 04:40 PM
moorepower's Avatar
The he351 will keep the ext down towing. Adding fuel is the only thing that will add much power. The turbo alone usually does not do much for power. You don't have to max out the power on the smarty!
Kenworth
Jul 15, 2008 04:18 PM
jmccart
Dec 19, 2007 12:49 AM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
14
Apr 23, 2007 06:46 PM
RAMV
Jul 14, 2004 12:08 PM
