white smoke, skip, and check gauges light on
Old Nov 12, 2018 | 06:58 AM
Mcmopar's Avatar
I've got an interesting one here. 2007 Ram 2500 4X4, auto. I pulled the head sent it off to Scheid to have it O-ringed. They said everything checked out ok. So I install the head and start the truck, white smoke a bad skip, it seems to go away above 1800 RPM's but I think I just cannot "feel" it. It's a full delete truck tuned since 2008 with the Smarty. It has codes, P063c and codes for injector numbers (trim codes). I'm using a Snap-On Solus Edge for troubleshooting. The "check gauges" light comes on after a few minutes, but I think that is part of the P063C code.
I've installed new injectors and crossover tubes, that had no affect on things. new fuel filter also. The really peculiar thing that I am running into is when I go try to do a "cylinder contribution test" my Snap on says the truck is not running, yet it clearly is. I've sent the ECM out to have it checked out, and the computer guy says it's fine. I asked that he verify the injector drivers are good, and he said yes. When I try to install the new injector trim codes, it looks like they are being accepted, but once you hit "ok" and the screeen refreshes a very odd thing happens, example, my code should be BTCGAL, after I input it, upon verification is comes back BTCG!A, very weird, I've never seen anything quite like this before.
Thoughts on this one? and Thank you.
Old Dec 9, 2018 | 09:52 PM
Mcmopar's Avatar
Nobody?
tbelue
Sep 1, 2011 07:46 PM
Thiss
May 24, 2011 07:58 PM
Lenn
May 13, 2006 10:36 PM
Mr. Jimmy
Oct 15, 2005 12:33 PM
quantrill88
May 30, 2003 09:25 PM
