What do I have?
Old Mar 27, 2009 | 07:44 PM
TurboShadow's Avatar
What do I have?
Hey guys, I work at a dodge dealership and they cleaned out the big pile of warranty stuff dodge didn't want back. I hauled home a he351vgt, and what appears to be a throttle body... But its odd. It was made by siemens VDO. It also looks like a drive by wire unit, no cable but has a 4 wire plug coming out of it, and defiantly has a electric motor in it. It also springs open not closed... and has a cummins part #! Now, I'm not new to diesel's and I KNOW they don't need a TB!
So anyone know what the heck this thing is? Some sort of intake brake? Im actually just trying to figure out how to control it. Its going to make a nice exhaust cutout on my sleeper turbo new yorker?
Old Mar 27, 2009 | 08:07 PM
BroncoHound's Avatar
Sounds like it is the EGR servo motor on the 6.7L's. Next time you have a 6.7L in your shop, take a look on the passenger side of the valve cover, sitting atop the EGR cooler. It should be the part you are looking at.
Old Mar 27, 2009 | 08:18 PM
well.... that kinda makes sense but this thing is HUGE! 3 1/4in inside diameter! It also does not have any soot in it at all... Has to be something to do to the intake Id think.
Old Mar 27, 2009 | 08:20 PM
C Pn: 4943075 Btw...
does it have a butterfly valve inside it? If so it is the EGR butterfly in the intake horn. It's located slightly down the intake horn from the EGR itself. Now that I reread your original post, it definately sounds like the EGR butterfly.
Old Mar 27, 2009 | 08:27 PM
Yup, it has a butterfly valve, thats why I thought it was a Throttle body. So, anyone know how to make this thing work? Or have the pinouts for the 4 prong plug? Ill probably just take it apart and figure it out.
Thanks Broncohound!
Old Mar 27, 2009 | 08:46 PM
What are you trying to do with it? Just playing with it or are you trying to put it on a truck? If the latter, it's only useful on a 6.7L truck with an EGR. It serves no purpose on the 6.7L other than to control the amount of fresh air intake versus EGR on an emissions-functional truck. When the butterfly is closed, the truck is running almost purely on EGR (fresh air is blocked off). When the butterfly is fully open, a corresponding smaller butterfly inside the EGR itself closes and the truck is running purely on fresh air. Of course, there are a million levels in between, giving a mixture of EGR and fresh air.
Old Mar 27, 2009 | 09:08 PM
Im going to use to as a 3 inch dump on a car I have. 3 inch to the back axle, dump, and then stock muffler out the back. Quite when I want it, loud when I need it
Old Mar 27, 2009 | 09:31 PM
Im not NEARLY electrical savvy enough to advise you on how to go about figuring out how to run a switch to power it in that application...lol...good luck though, sounds like a fun project.
Road Traveler
81
Nov 13, 2009 07:04 AM
Mark Thomas
Apr 30, 2006 08:20 AM
Intercooler
Jun 4, 2005 07:48 PM
routerguy99
17
Aug 11, 2003 12:21 PM
Nuttymopar
Apr 25, 2003 02:17 AM
