Water in air filter problem??
Old Feb 20, 2008 | 12:10 PM
mj007's Avatar
Originally Posted by jkitterman
You may have taken in a lot of snow and had freeze /thaw cycles and got sucked. It is common in powder snow.
Yeah, I noticed that I was getting a lot of bugs, dust, etc. on my filter in the warm months and, like you said, powder snow made it wet the first winter I had the truck. I finally removed the foam piece between the airbox and inner fender and then cut out the intake hole in the side of the airbox. That took care of both issues and I haven't pulled the filter minder since ... my 2¢
Old Feb 20, 2008 | 12:24 PM
mj007's Avatar
Originally Posted by Mindy
I let them change the filter. ( I dont go to the dealer, I go to a place called oil changers, its dealer warrantied)
Another thing to watch out for if you have ANYbody else check your filter is that they know enough to pull the filter out and look at the BOTTOM of it .... where the air comes in, NOT just pull the cover and look at the clean side. Sounds elementary but some lube/oil guys are not what you'd call 'highly trained'. A guy I know had been having his '01 serviced regularly at a 'jiffy lube' and they 'checked' the air filter every time BUT when the truck started throwing a fit we pulled the filter and it was like ..... uh ..... well ..... it looked like a wee bit of paved road on the bottom side! They had, I guess, been just popping the cover and ..... GOOD TO GO! Anyways, it seems like you're getting your problem solved so I'll just shut up now
Old Feb 20, 2008 | 02:08 PM
dj_souvlaki's Avatar
i would presonally stay away from the k&n. had it on for 20 000 km and i didn't like it. didn't notice any power diffence and decreased fuel miallege. im just using the factory mopar air filters. i get them at cost cause i work at a dealer thankfully.
Old Feb 20, 2008 | 02:13 PM
GMScott's Avatar
Well good luck with the K&N. On my '99 I used to pull the intake hose to the turbo off whenever I serviced the K&N. The turbo blades on the spindle were ALWAYS full of dust & crap. The truck was running the highway most of the time and never went off-road at all. I didn't over oil the filter and always let it thoroughly dry before reinstalling it. After seeing this each time I went back to the paper filters. Just my .02
Old Feb 20, 2008 | 04:09 PM
troll3193's Avatar
maybe it started as snow not water... I went through some big drifts a week ago, and just happened to change my filter right after. Found a bunch of snow in the airbox and some stuck on the filter.
Bryan
EverydayDiesel
22
Jun 3, 2010 12:10 AM
Wildhog
13
Aug 4, 2008 08:07 PM
herb
Jul 18, 2008 08:25 AM
nfsommer
Apr 16, 2007 09:21 PM
motrapper
May 3, 2006 05:37 PM
