Turbo remove/install
Old Feb 14, 2011 | 06:37 AM
rrking's Avatar
Can anyone post the procedure for removing/installing the turbocharger on a 2007.5 2500 with the 6.7? I've looked and I can't seem to come up with anything. Thanks.
Old Feb 14, 2011 | 09:08 AM
cbrahs's Avatar
6.7L DIESEL
Disconnect the battery negative cables.
Drain coolant.
Remove air filter housing.
Remove charge air cooler inlet tube at turbocharger inlet.
Disconnect turbocharger speed sensor electrical connector.
Disconnect turbocharger actuator electrical connector.
Remove turbocharger oil supply line.
Remove turbocharger coolant lines at engine block.
Remove RH engine mount. (you don't have to remove the mount but finaggle the turbo out. might be easier to remove cast elbow to make this happen)
Remove exhaust steady rest bracket from transmission.
Remove V-clamp from turbocharger exhaust outlet.
Remove turbocharger drain tube mounting bolts at turbocharger. Do not remove tube from cylinder block.
Lower vehicle.
Using Tool 9866, remove turbocharger mounting nuts. (no special tool needed but a nice universal)
Remove turbocharger from vehicle
Old Feb 14, 2011 | 02:56 PM
rrking's Avatar
cbrahs,
Thank you for that procedure. It is what I was looking for. Do you know if it is necessary to calibrate the actuator with Starscan or Holset software if the whole turbo assembly is replaced?
Old Feb 14, 2011 | 04:17 PM
J OOPS's Avatar
Why are you replacing the turbo?
Old Feb 14, 2011 | 04:31 PM
cbrahs's Avatar
Originally Posted by rrking
cbrahs,
no, install and run and check for leaks in coolant and exhaust and oil
RoadDiesel
Aug 7, 2012 06:06 PM
SmokinDodge12V
Apr 23, 2007 06:11 PM
dssimecek
Apr 9, 2007 09:53 AM
rnoland1970
Aug 21, 2005 01:25 PM
Dodgezilla
Jul 17, 2004 05:24 AM
