Turbo Just Replaced and Now P2000 Code
Old Sep 27, 2007 | 07:19 PM
ethamblin's Avatar
Like many, I have recently experienced the P2262 code which resulted in a turbo replacement around 7,500 miles. This was about a week ago. After replacement, truck performance seemed improved except I have just received a P2000 code today. Anyone experienced similar?
Old Sep 27, 2007 | 07:27 PM
Krazeeun's Avatar
nope... i've also had the turbo replaced... no such demon as the P2000 yet though
*** does it mean?
Old Sep 27, 2007 | 09:49 PM
ethamblin's Avatar
Forgot to mention that the generic OBD-II DTC P2000 code indicates "NOx Trap Efficiency Below Threshold". I'm curious if the faulty turbocharger has affected the NOx absorber...
Old Sep 27, 2007 | 10:03 PM
Krazeeun's Avatar
the knuckleheads at the dealership may have left a wire loose or something?
mine went back a week after turbo replacement to fix a massive oil geyser...
they didnt seat the oil return tube from the turbo all the way into the block
Old Oct 3, 2007 | 08:29 PM
ethamblin's Avatar
Update on P2000 code. I took my truck back to the dealer 3 days ago for the CEL and they claimed the did a search and could not find any flash updates or fix for the issue. Therefore, they cleared the code and sent me on my way. Though, I did have the manual high idle feature idled while in the shop - it's very nice. I guess we will have to wait to the newest info comes out on this problem.
Old Oct 10, 2007 | 01:53 PM
gellibee's Avatar
P2000 Code
Just recieved this same fault code. "Result" was a bad Oxygen Sensor Module. Hope this will take care of the throttle stumble as well?
Old Oct 10, 2007 | 04:23 PM
humboldt's Avatar
I had a similar code 2002 which was something like DPF below efficiency threshold. Turned out my DPF had failed indicated by lots of black smoke out the tailpipe. Dealer replaced DPF, no problems since.
Old Oct 10, 2007 | 07:03 PM
BigDBP's Avatar
The AU flash was supposed to fix that...I thought. I had that code and got the flash and haven't had any problems-
BigD
Old Oct 10, 2007 | 07:42 PM
ethamblin's Avatar
Guys, thanks for all the replies. So far, no repeat of p2000 code after code was cleared by dealer after 1,000 miles. Turbo is also performing well and seems to operate smoother with the exhaust compared to my original. Will keep posted. Thx again!
Old Nov 16, 2007 | 06:49 PM
shovel78's Avatar
new turbo
just got told turbo is shot truck stumbled bad CEL came on ran it for 2 days until i could get to the dealer.any info on why it went bad with just 3800 miles on it.2007 2500 6.7 4x4 6spd standard
Old Nov 16, 2007 | 08:31 PM
n0ne's Avatar
Turbo's seem to be dieing on the 6.7's ... not sure why.. But if you get P2262, you are pretty much guaranteed a new turbo.
Old Nov 17, 2007 | 08:13 AM
G-NOTE's Avatar
Question
Still the same old trick to check codes???
Turn the key on/off 3 times???
Old Nov 17, 2007 | 02:26 PM
n0ne's Avatar
yes.. That will show the codes, and clear ones that arent active.. If they are active, the CEL will stay on.. but you can use a programmer like bullydog or a edge juice w/ attitude to clear them... or take it into the shop and they can use the starscan.
rcs1218
16
Aug 5, 2009 04:02 PM
mr. ed
Mar 6, 2008 05:55 PM
mr. ed
0
Feb 26, 2008 05:45 PM
myfirsttruck
20
Oct 29, 2007 06:16 PM
59 cmnz
Sep 28, 2007 08:39 PM
