Torque Convertor Lock-Up
Old Mar 11, 2007 | 08:41 PM
71_340's Avatar
I just bought a new 07 Ram 5.9 w/auto. Is there any way to get the convertor to go into the lock-up mode a little earlier then the factory setting? I asked the service writer at my dealership and was told that they could not reprogram the ECM. I had the ECM reprogramed to compensate for the 295/70-17 tires I put on. I have to go about 51mph before the convertor locks up. The transmission shifts into fourth gear just a notch about 40mph under a light load.
Thanks for any input.
Sorry, I just noticed that I should have posted this in a different area.
Old Mar 11, 2007 | 09:28 PM
Tony T.'s Avatar
My 03 47RE shifts into OD at 42 to 44 mph, I wished it would hold 3rd gear lockup up to at least 50mph but it don't. Usually driving in town were the speed limit is 40 to 45 mph I will usually turn off the OD and drive in direct. Also when pulling a load I'll usually start out with OD off and when I get on the highway and get to rolling and terrian is right for OD I'll switch it back on.
Tony
Old Mar 12, 2007 | 09:16 AM
Luke S's Avatar
Use tow/haul mode. That'll make it lock up a lot quicker.
Old Mar 12, 2007 | 08:26 PM
tacook's Avatar
Here is another option people are trying out as well
https://www.dieseltruckresource.com/...=1#post1391876
Old Mar 12, 2007 | 08:27 PM
71_340's Avatar
Thanks
Thanks for the tip to use the Tow/Haul mode,hought that it would just raise the shift points. I will try that around town because I don't like all the slippage in the torque convertor while driving around 45mph; I really don't know why Dodge put a "loose" convertor behind a high torque diesel engine.
t8474kj1
15
Nov 17, 2010 07:36 AM
5.9Excursion
23
Jan 4, 2008 10:39 PM
budbon
Jul 6, 2007 06:28 PM
lombo
Jan 11, 2007 08:35 PM
0425004x4
Feb 16, 2006 07:16 AM
