Starter doesn't turn sometimes - have to disconnect/reconnect batt.
I have a totally stock 07 6.7 which has an intermittent starting problem. When
it happens, the starter does not turn and I hear no solenoid click. It doesn't even try to start. There is no CEL and all the idiot lights/gauges look normal. I found that if I disconnect the batteries and reconnect them, it starts right up every time.
I've had this happen about 20 - 30 times in the year I've owned this truck.
Has anyone else experienced (or solved) this problem?
I mentioned it to the dealer the last time it was in for a CEL and they said they've never heard of the problem and it (of course) didn't happen while it was in the shop. I was hoping to avoid the hassle of having it towed into the shop when it happens, but I had to "reboot" by truck TWICE today.
The next time it happens check your keyless remote. If that is inop also, your wcm is locking up. There is a TSB for this problem Ive seen it alot. You dont have to disconnect the batteries you can remove the IOD fuse for about 10 seconds and it will start.The IOD fuse usually has a plastc housing around it either black or white not the yellow one.
well i had to have my 07 junk towed yesterday because the truck just wouldnt start. lights worked, fuel pump kicked on,everything. jsut wouldnt do anything when i hit the key and the remote didnt work either. did i mention i was helping somebody move and had a trailer full of **** attached to my truck.........god sombody gimme an old truck with all mechanical stuff on it. 40k truck leaves me sitting cause of a key.......POS. But im not bitter though....
stanbnv
Jul 5, 2011 11:10 AM
Beast2B
Dec 8, 2009 01:44 PM
mr300x11
Oct 11, 2007 08:46 PM
Dave88LX
Mar 2, 2007 04:23 PM
