Special oil for the 6.7 .....
Old May 2, 2007 | 07:57 PM
bigman's Avatar
Whats the deal on the oil requirement for the 6.7 cummins. Seems i read some where that you have to run some expensive dodge crap instead of the tried and true rotella and delo. Whats the deal?
Old May 2, 2007 | 08:02 PM
fbx22's Avatar
wouldnt surprise me at all.
Old May 2, 2007 | 08:40 PM
keithstef's Avatar
From what I've found, the oil needs to have API CJ-4.
Shell Rotella T - Triple protection seems to cover
From the Shell website:-----
Shell Lubricants has introduced Shell ROTELLA®T with Triple Protection™ technology, a new and improved formulation designed to meet the new API CJ-4 service category for heavy-duty diesel engine oils. Shell ROTELLA®T with Triple Protection Technology™ provides significantly lower wear, exceptional deposit control and engine cleanliness for both pre-2007 engines and the latest performance and emissions systems technology found on new 2007 truck engines.
I picked up 3 gallon at Wally World for my 2007 Mega Cab 6.7. ie Cart before the horse.... Dealer mention the ship date was April 26, but shows in a holding area....
Old May 2, 2007 | 08:46 PM
gus's 03's Avatar
dello is just fine. just make sure you buy the new version ... itll say for 07- ultra low sulfur or something like that.. saw it at one wally world, they had new and old on the shelf.
Old May 2, 2007 | 08:53 PM
araratboy's Avatar
I talked to a service rep from the company that makes oil for our New Holland equipment. He said the new oil is a very low ash version that needs to be run because of the particle filter. He also said that you need to cut your oil change intervals in half with this oil. Would like to see some oil analysis to see what interval needs to be.
Old May 2, 2007 | 09:37 PM
gsbrockman's Avatar
At least your truck has been built !
Greg
Old May 3, 2007 | 04:43 PM
tankn60's Avatar
oil for 6.7
One thing that does not surprise me is that the service rep for the company that makes oil for New Holland said one needs to cut oil change intervals in half.
Old May 3, 2007 | 04:59 PM
DBLR's Avatar
If you burn LSD and use CJ-4 oil then you should cut your OCI in half as the new oil was not made for use with LSD only ULSD. It has a lower TBN number then CI-4+ oil does and LSD will wear it out faster IIRC.
Old May 4, 2007 | 12:03 PM
BlackSheep5's Avatar
you can run this in the 07's
AMSOIL Synthetic 5W-40 Premium Diesel Oil (DEO) is the premium choice diesel oil for model year 2007 and newer heavy-duty and pickup truck diesel engines requiring API CJ-4 emission quality oil standards.
http://www.amsoil.com/StoreFront/deo.aspx
Old May 5, 2007 | 06:34 PM
Outwest's Avatar
I used Delo and Napa gold filters every 3-4 thousand miles for ten years and 208,00 thousand on my 97 and it never used any oil between changes, even when I sold it. Unless I hear something negative about this combination I plan to do the same on the new truck. The new CJ-4 stuff naturally! Costco has always had a great price on case's of 6 gallons.
Old May 5, 2007 | 09:13 PM
fbx22's Avatar
Im intending on using Rotella T 5w40 synthethic mix from here on out. HD oil is HD oil as long as it has the right rating then its good enough. Dodge and its constant attempts to bully customers into their specific brand if this or that is getting really really old. If they keep it up I'll consider a duramax next time
Old May 14, 2007 | 05:16 AM
ib516's Avatar
"CJ-4" is what you need to run.
Old May 14, 2007 | 09:17 AM
Ga_Mike's Avatar
As long as its API CJ-4 compliant then you have nothing to worry about guys. I have some buddys that were getting upset from changing from old style oil they were using. ALL new diesels have to run this CJ-4 oil.......
Old May 14, 2007 | 11:47 PM
Road Traveler's Avatar
I can't remember the API rating of the new oil but you want the new oil like Rotella has. It is a low ash oil to be used in ULSD engines. I think delo has it as well!
Totallyrad
Jun 25, 2010 09:15 PM
Mechanos
Jan 29, 2004 09:01 PM
KenR
Jan 27, 2003 08:44 PM
Hired Gun
15
Jan 19, 2003 06:41 PM
Nov 4, 2002 12:03 PM
