6.7 Injector Failure After 70 Miles On It
Old May 3, 2007 | 11:45 PM
LOUIES RIDE's Avatar
Unhappy 6.7 Injector Failure After 70 Miles On It
Just Purchased A New 07 With 8 Miles, Went From A 99 F350 With 7.3 For This Truck. Drove Truck For 70 Miles And Started To Knock With A Misfire, Dealer Says Its A Injector But Parts Not Available? Could Be A Week Or Could Be A Month.
Anyone Had A Problem With Their 6.7??
Old May 4, 2007 | 06:32 AM
RyeThomas's Avatar
Winner winner chicken dinner!
That sucks. If its any consulation sometimes it takes a few miles to get the bugs out. Just be glad their not pulling the contaminated fuel bit and trying to make you pay. Although you are probably on the tank they gave you with the truck. Dont give up on the old Cummins just yet, shell come around.
Old May 4, 2007 | 07:36 AM
98.5POS's Avatar
6000 miles with no problems so far (knock on wood). Sorry to here about yout truck.
Old May 4, 2007 | 12:44 PM
rstone's Avatar
3000 miles and no problems so far either.
Old May 4, 2007 | 12:54 PM
vciesielski's Avatar
I would be telling the dealership to pull on off a truck in the lot.... and let them deal with star and the down time.
Old May 4, 2007 | 05:04 PM
eb290's Avatar
I second that. I've done nothing but change fluids and rotate the tires on my 07 cab and chassis, as of right now, 39,188 miles. No problems at all.
Old May 4, 2007 | 10:23 PM
Danchew6.7Mega's Avatar
I currently have 1200 miles no problems, 1st oil change at 1K miles.
Old May 5, 2007 | 02:00 PM
XLR8R's Avatar
You should call Cummins direct to see what the availability is... otherwise - the dealer needs to pull an injector off a truck on the lot to get you back on the road!
Old May 6, 2007 | 10:51 AM
catdiesel's Avatar
Make them give you a new truck......If not have them boroscope the cylinder hole WHILE YOU ARE THERE.......lets see how the top of the piston looks....could have broken a injector tip off.
Old May 6, 2007 | 11:19 AM
billindenver's Avatar
In colorado you get 3 days to change your mind on a major purchase. I would simply hand them back the keys and point at another one on the lot. Yeah, I'll take that one instead....thanks.
I would bet you a dollar to a donut they have yours running by the end of the day at that point.
Bill
Old May 6, 2007 | 11:43 AM
HammerDown's Avatar
Be glad it under warrantee, those electronic Injectors are awful expensive!
Old May 6, 2007 | 10:11 PM
monshine's Avatar
hello to all im new on here i had 5 dodge trucks now looking to get a 6.7 2500 reg cab 4x4 what should i know this will be my first diesel
Old May 7, 2007 | 07:31 PM
donhov's Avatar
I don't know about now but didn't Dodge have a 30 day trial and if unhappy return the truck??? If so I would offer your dealer 1 day to get it running correctly or "Sorry I'm unhappy and want to return it". In the long run you might be better if you can return it and get another. Wish I had done that on my 04.5 instead of loosing money and buying the 07 that replaced it.
If the above fails then Good luck but as some have suggested, see if Cummins had injectors in stock also and if so demand the dealer either remove one from an in stock truck or order one from Cummins.
Old May 7, 2007 | 07:39 PM
panama's Avatar
Yeah I second donhov I didn't take my 05 back for some problems and now i'm about to buy an 07 after having to deal with the all the problems they wouldn't cover under warrenty. If i had taken it back the first day and gotten another that would have been the wisest thing I had ever done.
Old May 7, 2007 | 08:21 PM
mitternocht's Avatar
This is exactly what the warrantee is for; obviously there was a defect in that injector to drop one that quick. I’d have them either give you a new truck off the lot or pull an injector off another new truck.
70 miles? You probably weren’t even home yet. Any dealership in their right mind should been over backwards to help you out in this situation.
