P0306 Code
Old Mar 15, 2008 | 03:11 PM
myfirsttruck's Avatar
P0306 Code
Have P0306 but NO CEL. Found it when I cycled the key just for fun. Cleared it off with the code clearer, started back up - no CEL but P0306 came back.
Any ideas?
Old Mar 15, 2008 | 03:25 PM
TreeFarm's Avatar
P0306 = Cylinder #6 misfiring.
Possible causes:
LOW FUEL
OTHER DTC’S
DAMAGED FUEL LINE
VALVE TRAIN
OBSTRUCTED FUEL INJECTOR SUPPLY LINE
DAMAGED OR OBSTRUCTED HIGH PRESSURE CONNECTOR
EXTERNAL DAMAGED FUEL INJECTOR
INTERNAL DAMAGED FUEL INJECTOR
NO COMPRESSION
EXCESSIVE ENGINE LEAK DOWN
The above is for an '05. I assume it is the same for other years.
Old Mar 15, 2008 | 05:10 PM
porkchop2245's Avatar
it is the same for the 6.7s sounds like you need to take her back to the shop
Old Mar 16, 2008 | 07:06 AM
If its that serious, why no CEL coming on?
sooty
Mar 5, 2014 08:40 AM
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
