New 8 Lug magazine DPF-LESS Exhaust system
Old Aug 8, 2007 | 11:32 AM
tcr's Avatar
tcr
Look at the new issue, Even though it's on a DMAX, there's hope. New exhaust system, turbo back, no DPF!!! Pretty cool for OFFROAD trucks only
Old Aug 8, 2007 | 06:14 PM
53 willys's Avatar
lets see a link to the company making it???
what did they do with the sensors???
Old Aug 8, 2007 | 06:16 PM
coolslice's Avatar
I think it's made by RBP.
Old Aug 8, 2007 | 06:50 PM
ShaneCTD600's Avatar
From reading the Ford and D-max forums it seems that they are not having the clogged dpf's or the reduced hp after removing the dpf. Not sure how but a D-max friend of mine mentioned that the tuner software for the Chevy's is more sophisticated and is able to ignore the sensors. Something to do with a program called something "live".
Old Aug 8, 2007 | 07:10 PM
Out Back 4x4's Avatar
EFI Live? most likely. i've heard it's a pretty good one for the gm products
Old Aug 9, 2007 | 06:25 AM
^^^ that's it!
Old Aug 9, 2007 | 06:42 AM
tcr's Avatar
tcr
Yep, it's RBP. They are plugging all the sensors right back into the exhaust stream. I wonder what would happen if the computer decided to dump some diesel into the exhaust and it was straitpiped. That might be pretty cool if it would ignite, put a switch on it. Instead of smoking people out, you could barbecue them! jk
Old Aug 9, 2007 | 07:13 AM
MikeyB's Avatar
If the sensors doesn't see a pressure differential in the DPF I don't think it will regen.
MikeyB
Old Aug 9, 2007 | 10:13 AM
ramtd02's Avatar
Instument guy at work got rid of his DPF on his 6.7.....he measured the clean DPF and there was 3psi drop!!!!!, so he wired in a resister simulating the 3psi drop, so he always has a clean dpf!!!
Old Aug 9, 2007 | 10:30 AM
Jeff K's Avatar
Instrument guys are awesome
Old Aug 9, 2007 | 12:00 PM
DieselGoose's Avatar
I need to find an instrument guy.
Old Aug 9, 2007 | 01:56 PM
tcr's Avatar
tcr
3psig is a heckova pressure drop! DPFs are evil considering EGTs, they'd have to be.
Old Aug 9, 2007 | 02:44 PM
C&C Milo's Avatar
Measuring the kind of flow these engines put out is not a trivial task. How was the 3 psi drop measured? That seems way too high. If all you need is a 10 cent resistor to simulate the voltage difference that is awesome. According to what I have read there are 3 oxygen sensors and 3 egt sensors in the system. Seems there is a lot going on beyond the pressure sensors.
Old Aug 10, 2007 | 12:38 AM
hatchy's Avatar
So what's the value of the resistor?
Old Aug 10, 2007 | 10:45 AM
ramtd02's Avatar
The 3 psi drop was measured by connecting too the pressure lines with a fluke, not sure what he added or took away in order too maintain this reading. BUt the actual 3 psi drop was taken @ 60mph on flat highway.
there was a total of 5 PSIG drop accross the whole system, 3 being in the DPF the remaining 2 accross 2 catalysts and a muffler.
I will talk to him at work and find out exactly what went into this and see if he will hook me up with a drawing.
