New 6.7 recall as of Oct 31st
Hey y'all that have the 6.7s out there a new recal hit us at the dealers on the 31st. What it is titled is a G30 recall and its for a replacement of the O2 sensor module that is mounted on the passenger side of your frame and it calls for a reflash of your ECM to the most current software available. If your ECM already has the up to date flash then its just for the module and takes about 10-20 minutes to install (depending on whats going on of course) and with the flash it usually takes around 45 minutes or so. Just letting yall know whats going on out there in the 6.7 world. Contact your local dealer and check it out.
well i dont just work on them im an owner too and i wish before i worked at a dealer that someone would have been willing to give me some heads up on info that the techs at dealers get
Put the last 8 digits into this site and it will let you know if you need the update.
http://www.dodge.com/webselfservice/...eenName=recall
About 5 minutes after I read this the dealer called & I got a notice in the mail. I'm hoping it helps with the stupid oil change code. 5,800 miles & I did a 2nd oil change, then 75 miles later it came back on and it won't reset.
BigTXDually
Nov 7, 2007 12:27 AM
