Manual trans and Highidle ?
Old Sep 23, 2007 | 07:54 PM
NOTSTK's Avatar
Can you have this enabled on the 6.7 for cold weather operation ? Truck is 07.5
6.7 3500 dually quadcab G56 Manual trans.
Old Sep 23, 2007 | 08:07 PM
rstone's Avatar
you can there a wire I think you have to ground out. Maybe someone will post that know how. My buddy has a 05 with g56 trans he had his done. You will even have to go to the dealer to get the program enable.
Old Sep 23, 2007 | 09:40 PM
KMKDiesel's Avatar
There is another method that is much easier get a 2by4 and cut to fit from peddle to seat at the idle you want
Old Sep 23, 2007 | 11:52 PM
ciamcoop's Avatar
I've asked around, I am in the same boat. You have to take it to the dealer and they can do, but there is something they have to add on to it. Cost to the consumer is around 300 bucks I guess. But yes it can be done.
Old Oct 3, 2007 | 06:23 PM
NOTSTK's Avatar
Need to know how or what it needs other than the 2x4. Dealer says no way I call bullsh!t it is supposed to have pto provisions *** how can you control your pto if you can't idle it higher ? ANYONE PLEASE its getting near zero here need high idle
Old Oct 3, 2007 | 07:22 PM
rstone's Avatar
I think there thread on the 5.9 forum you can pull up that show you how to do it on a 5.9. You may be able to look it up it might help you. Bodie Armstrong his name on here is armstrong performance you could pm him might know how cause I know he did my buddy 05 5.9. I know they are two different engine but maybe it the has the same wire you have to mess with. And you still have to go to the dealer and get then enable it.
Old Oct 11, 2007 | 10:10 PM
NOTSTK's Avatar
The dealer activated the PTO/High idle on my 6.7 G56 but it still doesn't work, is there a wire or pin to ground ?? If so what one ??
Old Oct 12, 2007 | 06:05 AM
myfirsttruck's Avatar
If the dealer turned it on - with the truck in park and foot off the brake - turn on cruise then hit set - it will go to 1100 rpm. You can then increase it incrementally with the accell button
Old Oct 12, 2007 | 06:36 AM
06 DIESEL's Avatar
You need a ground/jumper off of pin 22. I am sure that there is a thread on here that I have bookmarked at home. Just do a search and you should find it. It is a lot cheaper to buy the jumper wire from Cummins instead of the dealer, just an FYI.
Old Oct 15, 2007 | 08:13 PM
NOTSTK's Avatar
I tried the grounding pin #22 but it is used on the 07.5 6.7 w/ g56, any other ideas ?
Old Oct 18, 2007 | 08:31 PM
NOTSTK's Avatar
To the top
Old Oct 19, 2007 | 06:31 AM
BIGBEN2004's Avatar
Can't the SMARTY box enable it like the 5.9 or is their no SMARTY box for the 6.7 yet.
Old Oct 20, 2007 | 07:52 PM
NOTSTK's Avatar
No smarty for the 6.7 as far as i know, I have the p/n for the clutch switch ? or something you have to hook up then the high idle will work. I'll post the p/n when i get the part and verify that it works
Free89W350
Dec 28, 2011 11:18 AM
badzj999
Aug 20, 2010 05:17 PM
HecTiK
Nov 14, 2008 12:01 AM
djgaston
Oct 30, 2005 03:18 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
