How hot are ya'lls regens?
I've been reading on the ferd site that the tailpipe is getting up to 450 degrees and it even makes the bed of the truck hot. Are ya'll experiencing the same thing?
17k on the clock and NO regen as yet. However, speaking of how hot, had a boost leak develop and had to take to Dodge. They put the rubber exhaust hose on the pipe and torqued up the 6.7l a bit to hear where the boost was leaking and I thought the hose caught on fire!! Man what a stink, it was really burning!!
Great. I can see it now. I'm at the beach enjoying the scenery, sitting in the usual gridlock, and someone walking between cars gets his leg burned and sues me.
Another thought, doesnt regen only happen on the freeway?
Jeff
I gaurantee that if you truck has more than 500 miles on it (prolly even 300) it has regenerated the dpf. The fact that you can't tell you're doing a regen is a testament to the effort put into this new engine
You should not have the heat problems of the furd cause the vehicle will not regen in park (or at idle for more than a minute). If you were in a regen and went to idle, it will attempt to "maintain" some heat so that when you do drive away again it will be able to start the regen quickly.
Yes the overhead tells when the DPF is being regenerated. The exhuast is hot enough on mine that it could burn your leg if you held it there long enough - about 30 seconds would do it. I did it once not realizing how hot it was - levi's got really toasty! I know that it is not hot enough to change the tailpipe colors.
Actually I think it only tells you when the DPF is 80% or more full. The manual says if this happens you need to take it out for 45 minutes of 'highway driving' to get enough heat to clear the DPF.
So I'm pretty sure that the DPF regen is not noticeable on the overhead unless you do a lot of city driving and it gets up to 80% full. Today I noticed my truck was a little sluggish accelerating from a stop. After 30 minutes of highway driving it is back to normal. I'm thinking it did it's regen thing today and you can only feel it at really slow speeds. Once it gets going on the highway I noticed nothing different and it seems to have cleared up the DPF. No smoke or flames and the acceleration is back to normal.
There is an excellent discussion of this topic at:
http://www.cumminsforum.com/forum/6-...aning-dpf.html
Also see the link to the technical article on regen. This should put to rest all the speculation:
http://www.cumminsfiltration.com/fil...t_training.pdf
