high idle for 6.7
Old Apr 7, 2007 | 11:10 AM
rstone's Avatar
high idle for 6.7
I was wondering if you can get the high idle feature on the 6.7 auto like the 5.9 auto
Old Apr 7, 2007 | 12:00 PM
rstone's Avatar
does anybody know
Old Apr 7, 2007 | 04:10 PM
6 Shaker's Avatar
The one that I test drove this morning had the feature.
Old Apr 7, 2007 | 04:22 PM
Gbuilders's Avatar
what is the high idle feature and what does it do?
Old Apr 8, 2007 | 01:13 PM
bob4x4's Avatar
The 6.7 autos both C&C and p/ups have it available.............I have enabled it on both.Just as in previous models it is turned on with the cruise switch and adjusted with the rt hand switches.
Bob
Old Apr 8, 2007 | 04:07 PM
rstone's Avatar
tried mine with crusie switch and it did not work do have to take it by dealer and get them to enable it.
Old Apr 8, 2007 | 05:41 PM
Monkey 456's Avatar
I am interested in that their idle thing. What is it fer?
Old Apr 8, 2007 | 10:45 PM
GMScott's Avatar
Mine is not enabled either. Guess that will be on the list for the first visit back to the dealer.
Also, had quickly read that you can get faster warmups with the exhaust brake. Haven't had time to read the manual yet about this. Anyone know??
Old Apr 12, 2007 | 09:37 AM
fade94's Avatar
When it's cold, say less then 32 deg, the truck will idle up to 1200 or so RPM automatically. Hope this helps.
Old Jun 13, 2007 | 11:41 AM
rstone's Avatar
I went to the dealer today and they turn mine high idle on for no charge. Do you think if you have to idle with the 6.7 and idle it up to 1500 rpm would be better than letting it idle at 800 rpms?
Old Jun 13, 2007 | 03:12 PM
GMScott's Avatar
Had my high idle enabled by the dealer. Mine only works in Park. On my 04.5 the high idle would work in both Park & Neutral. Can you get it to work in Neutral?? I used to use it in Neutral for warming up as I have read here that the 48re didn't circulate fluid in Park. Don't know about the new 6spd auto.
Old Jun 13, 2007 | 03:19 PM
dodgezilla04's Avatar
all the trucks(newer) have the automatic high idle when the coolant and outdoor temps are lower than 38*.
the high idle that is being refered to is driver controllable. you can do it anytime the brake and throttle isnt being touched(manual trans) dont know if the auto's have to be in park or neutral.
allows idle speed to be adjusted from 750 to 1500 rpm. aids in warm up, prevent cylinder washing from extended 750rpm idles.
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
