Got clutch smoking hot. What to change?
Old Aug 24, 2007 | 10:02 AM
Kurt Smith's Avatar
My 6.7 manual only has 600 miles. Last night I got myself in a situation where I HAD to BACK a 2000 lbs trailer up a steep and narrow incline. Okay so steep I that when I stopped in the middle I had to engage 4wd to get going again. Not being a pro at this I had to pull forward and adjust a few times and of course that meant riding the clutch.
The clutch got so hot it was smoking like a tire fire and smelling like one too. Other than not doing this again (that tuner doesn't need to work on my toys that bad ) what should I do for the pickup? Change tranny fluid?
Old Aug 24, 2007 | 10:04 AM
rustyshakelford's Avatar
your tranny fluid is probably fine, you just got your clutch hot. upgrade to a southbend or practice backing more so you dont have to pull foward so much
just kidding btw...i know how sensative you 6.7 guys are
brett
Old Aug 24, 2007 | 10:07 AM
Kurt Smith's Avatar
Hey I am not sensitive... my girlfriend got a little sensitive about my speech patterns last night though. Girls...
Thanks for the advice!
Old Aug 24, 2007 | 10:09 AM
CTD03's Avatar
back up in 4 low problem is fixed
Old Aug 24, 2007 | 10:17 AM
Kurt Smith's Avatar
I did use it a little. It was binding up pretty bad on the pavement though. On second thought though the diffs probably would have gotten less wear on them than that clutch did.
Old Aug 24, 2007 | 11:16 AM
KMKDiesel's Avatar
just breaking it in
You are just breaking your clutch in. I have had smoke rolling off mine three different times now. It still has no problems engaging or anything. The stock clutches are just weak about slipping. As soon as you get it hot it will slip way bad. The worst time I slippped mine was sled pullin and it was pouring out white smoke bad, I could smell it for a couple days. The best clutch for your situation is a 550 horsepower south bend clutch with the hydralic upgrade, just for parts you are looking at $1300 not bad I dont think. Good luck
Old Aug 24, 2007 | 11:25 AM
06 DIESEL's Avatar
I have had mine extremely hot a few times, smelled it for a week after one of the times. It is still holding but I just put my Predator on last night and have not had a chance to see if it is slipping yet or not since I only go 7 miles to work and it is all stop and go traffic. I would say use it until it won't hold anymore then get a South Bend DD with hydrolic upgrade and you should be fine. $0.02
Old Aug 24, 2007 | 01:41 PM
Kurt Smith's Avatar
Thanks for the info guys because it puts mind at ease. I knew I was abusing the plates but the smell was so bad etc. I was wondering if it got so hot it was vaporizing oil. The smell is still in the truck this morning as you say. thanks again.
Old Aug 24, 2007 | 03:00 PM
KMKDiesel's Avatar
You do not want the dual disk south bend, It is drivable for everyday driving but it is real rough and loud you will hear it over the sound of the motor. If you are not going to make it a drag racing truck or sledpullin truck there is no need for the dual disk the 550 hp single disc is all that you will need with the hydralic upgrade or you stock system will be shot in no time
Old Aug 25, 2007 | 10:38 AM
XLR8R's Avatar
I thought the dual disc clutch that SB makes for the dual-mass G56 is supposed to be quieter.
Old Aug 25, 2007 | 10:51 AM
06 DIESEL's Avatar
I also thought the same.
Old Aug 25, 2007 | 04:40 PM
KMKDiesel's Avatar
My bad sorry about that sb makes a dd street clutch and a dd sled pulling clutch so you should be able to get a dual disk street clutch from 550 hp to 850 hp for a that are still capable of sled pullin and drag racing. And they are not as bad to drive as the normal dd sled pullin clutch
Old Aug 25, 2007 | 07:48 PM
72dart's Avatar
This is one of the reasons why I like Ford manual hubs over the Dodge design. We could then use our 4x4 low range. I hope to see this on Dodge's new style trucks!
Old Aug 25, 2007 | 07:51 PM
bnold's Avatar
I use 2 LO on my truck all the time!! Just flip a switch and throw the lever... Think I spent all of $5 on that mod...
Old Aug 25, 2007 | 08:20 PM
kev94mx's Avatar
I got mine hot today. I have had alot of manuals in my time but this one will heat up in a second. My 05 was night and day better than this one. I am not going to complain to much though because its better than the piece of crap auto I had.
