Fuel problem
Old Oct 16, 2010 | 10:03 PM
wheatwhacker's Avatar
Fuel problem
Hey.
I had an issue with my truck a few months ago. Low fuel pressure code came on and truck showed signs of fuel starvation. I replaced the filter and it ran fine, engine light went off and all was good.
Today, I hooked up to my trailer, gave it some shoe and problem came back, spluttering and light came back on.
I nursed the truck home, unhooked trailer and drove lightly for 20 miles, no problems.
Seems like that there is a fuel blockage somewhere. I get fuel from a bowser at work and sometimes fuel from my inbed tank in a construction environment so I suspect a blockage somewhere. I have an 2007 5.9 with the upgraded in tank pump.
Where should I start to look?
Old Oct 16, 2010 | 10:57 PM
johnh's Avatar
Originally Posted by wheatwhacker
Hey.
i would change filter again and note any debris that may be in there
Old Oct 16, 2010 | 11:01 PM
I was wondering if there was a filter in the tank that needs cleaning. If the pump is in the tank, there has to be a filter in there to protect it, correct?
I have only done 1000 miles since replacing the filter on the motor side.
Old Oct 17, 2010 | 09:10 AM
Kowalski's Avatar
There is screen holes in the basket in the tank along with a kind of a filter screen before the pump intake in the tank but not a serviceable item. The problem could also be your in tank pump is taking a dump. When the dealer did the conversion to move mine into tank it crapped in a year, always bought fuel from service stations no slip tanks.
Old Oct 17, 2010 | 11:56 AM
wonder if i blow air back the line
Old Oct 17, 2010 | 04:58 PM
Blake Clark's Avatar
This. Check the fuel line going from the filter housing to the injector pump. There is a screen there and I bet its gunked up.
Old Oct 24, 2010 | 09:52 AM
Prolem came back today. Changed filter and there was some dirt in the housing. Where is that screen between the filter and the injrctor pump?
Old Oct 24, 2010 | 10:39 AM
In the line right off of the filter housing going to the CP3.
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
