Ford’s Torqshift VS Aisin / 68RFE
Old Feb 26, 2007 | 09:50 PM
bluesurf's Avatar
is it possible that you could put the aisn 6 spd auto on a 5.9 as a retro fit?
Old Feb 27, 2007 | 11:38 AM
bigblock2stroke's Avatar
Originally Posted by Pile Buck
Has anybody heard if these new transmissions are going to have a tow / haul mode like the Torqshift? I think that’s one of the best options I seen in a long time. When pulling heavy loads it works almost as good a manual for holding back.
I went up to my buddy’s place yesterday to pickup his 2000 3/4-ton Dodge to take it into the shop. Injector pump went out . He is really thinking about upgrading to the new 2007 3500 as I’ am , so he was asking this question, because he really likes the tow / haul mode in my F-550.
VGT braking enabled is standard now (as noted above).
tow/haul is there. ERS (electronic range select) is also standard, which can be used to block out 6th (OD off).
You can drive them without ever using the service brakes, just tap the button to downshift and use the VGT braking (which provides more braking power than the butterfly valve version BTW) to get to about 10 mph. Then you have to use the brakes.
Cummins VGT braking will provide far more braking power than either GM or Ford.
Old Mar 2, 2007 | 09:06 AM
Crabjoe's Avatar
Ok.. Which tranny is this or will both the Aisian and 68RFE have the same features?
Old Mar 2, 2007 | 10:10 AM
Luke S's Avatar
Both of them.
Old Mar 3, 2007 | 11:45 PM
morkable's Avatar
what are the differences between the 68 and the aisen?
Kevin
isbeinside
26
Nov 17, 2016 01:51 PM
Wobblin-Goblin
34
May 10, 2015 09:07 PM
Valv
Jan 16, 2009 05:46 PM
flubyux2
Jan 30, 2007 02:25 PM
Luke S
Aug 9, 2006 05:06 PM
