Exhaust Brake question
Old Sep 18, 2008 | 11:57 AM
J3Cub's Avatar
I have a new 2008, 3500, 6.7
I have noticed that the Exhaust Brake comes on strong, but at about 1600 RPM, down to about 1400 RPM, it lets off about half the braking power, and around 1400, it comes back on strong.
Is this normal, and what is Dodge’s reason for this, and can this be fixed so it will come on even throughout the RPM range?
Old Sep 18, 2008 | 12:11 PM
Totallyrad's Avatar
I don't think it should fluctuate like that. There have been some turbo issues with the variable geometry turbo on the 6.7. You may be experiencing some of that. If you're still under warranty, I'd take it in and at least have them look at it so you have it documented the problem exists.
Old Sep 18, 2008 | 12:25 PM
P.J's Avatar
P.J
Auto or manual?
Old Sep 18, 2008 | 02:10 PM
J3Cub's Avatar
It is a 6 speed manual, with about 7000 miles.
Old Sep 18, 2008 | 03:36 PM
P.J's Avatar
P.J
Take it to the dealer.
It if were evenly braking less as rpms fell I would call it normal (less back pressure).
Old Sep 18, 2008 | 04:32 PM
mastercaster's Avatar
mine started doing that after the second flash or so. i am on AX now. it went away with the exhaust and egr deletes though. now the eb is stronger than ever all the way down to 1100rpm. i think it has to do with the flash and egr.
Old Sep 19, 2008 | 08:03 AM
J3Cub's Avatar
Thanks, I disconected the EGR yesterday, and will do the delete and Smarty soon.
Old Sep 19, 2008 | 12:16 PM
Bando's Avatar
MasterCaster,
It went away with the deletes because the exhaust break only does this(loses pressure around 1600rpms) during regeneration. It was something in the programming of the latest flashes.
Hoss
Nov 10, 2012 04:45 PM
Mopar440_6
Feb 11, 2007 10:50 PM
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
