Drain?
Old Mar 16, 2013 | 09:08 PM
warriorboomz33's Avatar
Drain?
I walked over to my truck this morning and found a small puddle of water that formed underneath and just forward of the passenger side. I popped the hood and checked the air conditioning condenser but there was no moister around it. I poked around and saw where the moisture was coming from. It was coming from what looked like a drain. But, I don't remember running my air conditioner anytime during the recent days. The picture attached shows what I'm talking about. If this is normal, then I'm not worried about it.
Thoughts anyone?
Thanks.
WB
Old Mar 17, 2013 | 07:51 AM
Rrloren1's Avatar
I just recently had similar leak in the same area and it turned out to be the water pump. My temp gauge was showing about 10 - 15 degrees hotter than normal.
Check your water bottle , if it's low that may be your problem.
Old Mar 17, 2013 | 09:11 AM
BigIron70's Avatar
Cummins Guru
AC drain normal to see water dripping out.
Old Mar 17, 2013 | 10:56 AM
@Rrloren1: Thanks, I'll check, but my temps have been running normally. @BigIron70: That's a relief, thanks. Not sure why it would've been draining because I don't remember that I ran the AC. I guess it could be some residual condensation of some sort.
Old Mar 17, 2013 | 11:30 AM
BigIron70's Avatar
Cummins Guru
When you are in defrost mode ac compressor will run. Normal operation otherwise vehicle windshield will fog up.
klx650a2
Jan 10, 2008 12:08 AM
wooff
May 1, 2003 11:22 AM
Dodgezilla
Nov 24, 2002 07:31 AM
cpermd
Oct 28, 2002 02:19 PM
