Code 2563
Old Jul 16, 2010 | 07:18 PM
38short's Avatar
Code 2563
CEl came on with a strange code not listed under the 6.7 trouble codes.P2563. It has something to do with the turbocharger boost control positon sensor. Any ideas on what's going on . Is the turbo going out, or is it just the sensor giving problems. Also where is the sensor located at??
Old Jul 16, 2010 | 08:50 PM
Blake Clark's Avatar
A flash should take care of it.
If its underwarranty and stock, take it in a let dodge take care of it.
If its the truck in the sig, Im baffled.
Old Jul 16, 2010 | 09:27 PM
38short's Avatar
Code 2563
The truck is my work truck. It has 131,000 plus on the OD. The guy on the other forum said the commanded position of the turbocharger and the actual position of the turbo aren"t agreeing with each other. Maybe recalibrating the actuator would fix it. Hey, I 'm just a truck driver, will see what happens if I keep running it.
Old Jul 16, 2010 | 10:15 PM
Run hard and heavy with the exhaust break on. This may work the slider nozzle enough to clean it up and stop the code from popping up.
NVoutfitters
Jul 12, 2011 06:54 PM
kthiemann
Aug 26, 2010 06:22 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
