Check under hood
Old Oct 14, 2007 | 07:47 PM
scootertrash35's Avatar
Check under hood
while checking fluids etc., i noticed the heat/sound deadener was sagging off of the firewall and laying on the upper heater hose making a noticeable mark on it.put a small sheet metal screw through it into the firewall.then i checked the other truck and sure enough it was the same.
Old Oct 16, 2007 | 08:49 PM
wreedCTD's Avatar
my truck has oil on the block from that tube to the rear of the block. i have wiped it off and its hasnt come back, should i be worried?
what is that tube coming out of the block right there in his first pic?
Old Oct 16, 2007 | 08:53 PM
wreedCTD's Avatar
oops i guess i should read, he says its the upper heater hose. sorry guys.
Old Oct 18, 2007 | 08:39 PM
231jasons's Avatar
Mine did the same, i fixed it with a 3"plastic washer and a sheet metal screw.
Dougk
Jan 30, 2010 12:11 PM
Eddy Reyes
18
Jun 28, 2007 12:06 PM
Dodgezilla
Feb 13, 2004 03:40 PM
rjweiss
Oct 14, 2003 07:05 AM
DarrellB
13
Jan 15, 2003 02:37 AM
