CEL on, cant get code
Old Nov 17, 2007 | 03:36 PM
slingnasty's Avatar
Lightbulb CEL on, cant get code
my CEL came on today on my way home. 3800 miles. I called dealer after I did the VIN lookup and it's due for the upgrade and o2 replacement. Should I be cautious driving around this weekend? I plan on getting fixed monday I just dont want to be left stranded. Thanks for any input.
Old Nov 17, 2007 | 04:05 PM
KMKDiesel's Avatar
They have no idea if it has to do with the recall because you dont know the code. Get in your truck start with key in the off position and turn on and off 3 times farely quick and leave on, on the third time and were your milage is diplayed it will tell you your code. Then post on here. You might have to set your park brake and I hold one hand on the key release button make sure it is all the way off.
Old Nov 17, 2007 | 04:23 PM
slingnasty's Avatar
I tried the 3 times on/off but no luck. What happens on the third time left on is the CEL blinks 5 times then stays solid. Any ideas with that? I tried both fast/slow on the on/off trick but no dice. Thanks.
Old Nov 18, 2007 | 08:18 PM
worktrk's Avatar
You have to turn the key just about as fast as you can, with the e-brake on and all the doors closed. Trust me you will need to know how to do this with one of these trucks. I have 18k miles on mine and I can't tell you how many time the cel came on, but when I checked it there was no trouble code stored. I have all the code discriptions but I don't know how to post an attachment, so if you need to know what your code let me know.
Old Nov 19, 2007 | 06:57 PM
slingnasty's Avatar
thanks i will give that a shot. Right now the CEL is off, I have an apt scheduled for Wed to get the latest flash and the o2 module replaced. I will see what I can find out from the dealer on latest codes etc if there happens to be any newer.
Old Nov 19, 2007 | 07:02 PM
Bob Wagner's Avatar
abs codes can set a check engine light and not be read. A scan tool or smarty will reset the code
Old Nov 24, 2007 | 08:40 PM
skeeterboy's Avatar
Push in the emerg. brake and do the on/off trick 3x and it should work....
03f3507.3
Oct 15, 2009 07:44 PM
MrSuzuki
Jun 16, 2009 12:23 AM
boaterman
Oct 15, 2008 10:44 AM
Hillbilly Delux
Mar 20, 2008 05:01 PM
mx684
Nov 28, 2007 09:05 PM
