PO882 Code I cant get rid of!!
Ok im running an 04.5 commonrail with a 48re in my 2003 F350 and I have tried to fix this code to no avail....the code is transmission control relay voltage too low...I wired in the relay I was told to do running a 15amp fused wire from the battery to the 30 on the relay, a ground wire to 86 on the relay, the yellow/orange wire(T16 for the transmission control relay output that goes to the transmission) to 87 on the relay, and then the yellow/dark blue wire(t515 for the transmission control relay control that goes to the ecm) to 85 on the relay. To my knowledge this is the only wiring that would affect this so does this mean my TCM is bad? or am I wiring something wrong? I believe this is why my tranny is in limp mode and not locking the converter properly...
Theory of Operation
The Transmission Control Output from the Totally Integrated Power Module (TIPM) supplies power to the TCC,
Overdrive, and Governor Pressure Solenoids when in normal operating mode. The Transmission Control circuit is
constantly monitored by the ECM. If the expected state of the Transmission Control circuit is different then the
expected state, a corresponding DTC will set and the ECM will de-energize the Transmission Control and place the
transmission in Limp-in.
² When Monitored:
Continuously with the Ignition on.
² Set Condition:
This DTC will set if the ECM monitored voltage of the Transmission Control Relay Control circuit is different
than the expected voltage for the period 3.0 seconds.
Possible Causes
(T515) TRANSMISSION CONTROL CIRCUIT OPEN
(T515) TRANSMISSION CONTROL CIRCUIT SHORT TO GROUND
(T515) TRANSMISSION CONTROL CIRCUIT SHORT TO ANOTHER CIRCUIT
TOTALLY INTEGRATED POWER MODULE (TIPM)
ENGINE CONTROL MODULE
² When Monitored:
² Set Condition:
Possible Causes
trans help
the trans. cont. sol. recieves it power from fuse#5-40a to term. #30 , term 86- recieves power thru pin 2 -c5 to pin 6-c4to fuse #50-10a, term 85 to t515 yl/db pin 16-c5 to pin 31-c2 ECM , term 87-yl/or pin 14-c6to pin#1on trans sol assy to t118 dg ,t9 dg/tn, t75yl/lb , ECM c2-pin 14 t118 gov press sol, c-2 pin 15 t-9 shift sol cont ,c2 pin 25-t75 torq conv clutch sol cont . hope this helps this is from the wiring diagrams I do not know how to copy and paste
slingnasty
Nov 24, 2007 08:40 PM
VikingDiesel
30
Nov 13, 2007 05:29 PM
