Another Regen QUESTION
Old Mar 7, 2008 | 03:02 PM
wcbrownhound's Avatar
Just wanted to know if the Cummins engine is having the same problems as the other 2 with the regen when you start installing tuners, or monkeying around with the trucks programing. I just want to know if you leave them stock are they giving any trouble as a majority. JUST WONDERING. THANKS.
Old Mar 7, 2008 | 05:49 PM
mnmlod's Avatar
I haven't had a bit of trouble with mine at 10,000 miles so far. My motor is stock though.
Old Mar 7, 2008 | 08:22 PM
coolbreeze's Avatar
Stock is good.
Old Mar 8, 2008 | 10:41 PM
T210DRVR's Avatar
Based on comments from TDR I'd say the majority of stock engines are doing fine. However, my best guess is that 10-15% are having troubles. The latest reflashes seem to be taking care of most of the problems, but there are still a few out there that are experiencing difficulty.
At least we haven't seen any major problems with injectors and that sort of thing. Fuel dilution of the oil is a problem with trucks that aren't worked hard as they must go through an active regen more often. Oil change interval will be indicated more often than expected with engines driven around town.
Old Mar 9, 2008 | 07:25 AM
Rrloren's Avatar
Have 15000 on mine and had 2 flashes done and new O2 sensor . Never had a minute's problem with it , just thru codes a few times. Seems OK now after sensor replaced and latest flash.
Old Mar 9, 2008 | 10:27 AM
mnmlod's Avatar
My last reflash was done back in July and I haven't had one since. I am waiting, per the service dept., for the newest reflash because the o2 sensors are on backorder? Does that sound right? I still haven't had a bit of trouble though.
jwatso8
Jan 13, 2011 10:55 AM
Jchavez
Jan 11, 2011 08:50 AM
Ranhil
14
Apr 6, 2009 11:59 AM
duckbill
May 4, 2007 07:38 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
