how do you reset overhead codes?
Old May 21, 2007 | 09:49 PM
circlerangus's Avatar
I bought my 6.7 cab/chassis today and brought it home and put l.e.d. lights throughout the bed. now im getting a message in the overhead console that the both rear turn signals are out. and they are flashing unusually fast any ideas??
Old May 21, 2007 | 11:10 PM
donhov's Avatar
There were a few posts about this issuee a while back. I think that the issue is that some type of resistor has to be installed so that the computer sees the proper resistance that the LED's do not create.
Do a search and hopefully you will find an answer.
Old May 22, 2007 | 12:01 PM
Hillbilly Delux's Avatar
i just put 2 regular tailights in my headache rack, everything else is led, i did the same thing
Old May 22, 2007 | 12:21 PM
SolarYellow05's Avatar
I haven't tried this, but the dealer told me that if I put LEDs in the parking lights in the front, then it would all work alright. The entire circuit has to have the same type of bulbs so the computer doesn't think there's a drop in voltage at the light.
Old Mar 4, 2008 | 10:30 PM
f272272's Avatar
I have the same problem with both tailights being out? Any ideas other than the bad ground ideas I keep getting?
Old Mar 4, 2008 | 10:52 PM
1stGen545's Avatar
Wire any extra lights into the trailer plug. The computer uses checks resistance to since bulbs that are out. That's why your turn signals are going fast, just like a bulb being out use to do to the old ones. Don't you just love all these new features for idiots, it will also tell you when you have a low tire. If you cant tell you have a low tire you should not be driving on public roads.
Old Mar 4, 2008 | 11:18 PM
f272272's Avatar
Mine is a cab/chassis and I have no extra lights other than the ones that came mounted on the flat bed. I also get a small glow out of the drivers side headlight when i tap my brakes. I only notice this glow when the headlights are off.
Old Mar 7, 2008 | 10:47 AM
chilly's Avatar
When the spring thaw comes I will have to find a hot full-time lead for my internal camper lights. Any suggestions on where to look? I have read that the computer on the "08" reads amperage and will turn things off if you tap into the wrong one.
Old Mar 9, 2008 | 01:13 PM
1stGen545's Avatar
If you have the tow pacage you will have a Key on hot to the 7-prong plug on the rear that you can tap into. I belive its the lower left corner but use a test light or DVOM just to be sure. It will say on the cover of the plug it will show a +.
hallio217
Jan 9, 2014 11:41 PM
rip 112
16
Jan 15, 2010 02:46 AM
rmb93243
Jul 9, 2004 12:51 AM
2500CTD
May 24, 2004 10:31 PM
jt
Nov 17, 2003 05:26 PM
