6.7L Slow Idle
Old Jul 4, 2007 | 11:08 AM
DodgeDude_6.7L's Avatar
6.7L Slow Idle
I have just bought a new '07 3500 SRW 6.7L 4X4 auto. I have noticed that it idles around 680 RPM when in drive and in park. When I put it in reverse it drops down to about 500 RPM and feels like the power steering pump is having trouble turning the wheels . Also when I am slowing down to stop at a light, RPM drops down to about 600 before it downshifts to the next gear to bring the RPM back up to idle speed. Is this normal? I read in the manual that idle is supposed to be between 700-800 RPM for the 6.7L. Does anyone have a 6.7L that behaves like this or have any suggestions?
Old Jul 5, 2007 | 08:12 AM
Rrloren's Avatar
Take it back to the Dealer and have it adjusted for free.
Old Jul 5, 2007 | 08:27 AM
2007Dually6.7's Avatar
Yeah I would take it to the dealer and let them adjust it. I normally idle around 800. you should get them to enable your High idle. It allows the oil to circulate better and you can adjust your idle up to 1500 rpm while the truck is in park. I dont know why the dont come enabled. Hope it all works out
Old Jul 5, 2007 | 10:47 AM
Rrloren's Avatar
Dually, I had my high idle activated , can you explain how to make it work?
Old Jul 5, 2007 | 08:14 PM
metalaram's Avatar
when engine is running with trans in park push cruise on then push set. idle should go to 1100 rpm then use accel a few times to raise it about 100 rpm at a time or hold till 1500 rpm which is max. it is the same as using cruise when driving....chris
Old Jul 5, 2007 | 08:35 PM
GMScott's Avatar
With my 04.5 I could engage the high idle in both Park & Neutral. The 07 6.7L will only engage the high idle in park. Is this something that can be changed by the tech with the scanner?? I noticed there were a bunch of options that can be enabled by the tech with the scanner while I was looking over his shoulder but didn't know what they all were.
Old Jul 6, 2007 | 10:40 AM
Rrloren's Avatar
Yeah that does it , works sweet. Don't understand why they don't come activated from Factory with instructions in the Owner's Manual? That's a nice feature for cold weather and I'll bet most owners don't know they have it on their truck.
Old Jul 6, 2007 | 06:11 PM
I took my truck in to have them increase the idle speed. They said that they could not adjust the idle speed because it was a built in parameter. Is this true? Any suggestions? What RPM does any of your trucks run at when stopped in reverse?
Old Jul 10, 2007 | 04:07 PM
Sorry Rrloren i didnt get back to you in time... but you got plenty of people to get you the right answer. You like it so far? I run around 800rpm in park... ill check it today in reverse and get back with you about that. It does seem strange that they cant make it idle higher though, but with all the restrictions on the new truck it wouldnt suprise me
Old Jul 10, 2007 | 07:33 PM
Ship Fixer's Avatar
Talking Ditto on the slow idle
Picked up my new ride 5 days ago, noticed the slow labored idle in reverse right away, but hey who idles in reverse that long anyway? Only other comment is HOLY %@#& ! ! ! I thought my '02 F-350, 7.3 factory high torque tuned was about as bad as they come hauling my 12K fifth wheel; hooked up the new ride over the weekend, right out of the box - 65 up hill and backing off the throttle ! ! The truck is awsome ! ! !
Old Jul 10, 2007 | 08:41 PM
Ya, my truck pulls like a Semi, lots of power, and acceleration, loaded or unloaded, nothing slows this thing down. The only questionable thing about it is the slow idle.
Ship Fixer, What RPM does yours idle at in park?
Old Jul 11, 2007 | 10:07 AM
Ship Fixer's Avatar
Dodge Dude, mine idles about 7-1/4 in park, drops to about 5 - 550 in reverse. Still got lots to learn about it, bought it just to tow toys so it dosn't get driven every day .
Old Jul 11, 2007 | 11:33 AM
Yeah i checked mine, in reverse its around 600... it still drives fine so oh well
Old Jul 12, 2007 | 08:34 AM
I guess you are right, it runs great, so who cares. Thanks for all of your comments.
dobbietwo
Feb 16, 2011 12:05 PM
Goofball
Aug 22, 2009 10:08 AM
guitarman
Feb 27, 2009 07:42 PM
Buffman88
Jan 22, 2006 08:25 AM
