idle's down real slow
Old Jan 21, 2006 | 10:06 PM
Buffman88's Avatar
i have a 1990 dodge d250....when i hit the gas and let off it takes a while for it to idle down does anybody know what the problem could be?
Thanks
Old Jan 21, 2006 | 10:12 PM
Fuel screw is turned in too far.
Old Jan 22, 2006 | 12:26 AM
paccool's Avatar
If you have done much tweaking and turning of the fuel screw, you may be close to a run away condition. BE CAREFUL!
Old Jan 22, 2006 | 08:18 AM
Buffman88's Avatar
sorry about all the questions but where is the fuel screw located...do i have to pop off the cap on the pump?
Old Jan 22, 2006 | 08:21 AM
Racer9's Avatar
Try a little oil on your linkages,pedal, and cables. Check return springs.
Old Jan 22, 2006 | 08:25 AM
Is this truck new to you or have you had it a while?
If you have had the truck a while and this is a new problem, I suspect something is binding in the throttle linkage. Probably the bellcrank between the accelerator cable and the throttle rod.
If this truck is new to you , the fuel screw is located on the back of the pump, just above the shutoff solenoid (the thing with 2 wires on it). If it has not been messed with (tamper proof cap on it), the problem is in the linkage. If there is no cap on it, somebody turned it in a little too far. Back it off 1/2 turn and you should be good. The screw is 6 mm, the locknut is 13 mm. You may have to speed the idle up a little after adjusting on this unless the idle is already too fast.
DAN POUCHER
Jun 14, 2008 06:52 PM
DAN POUCHER
May 7, 2008 07:23 AM
90dodge
39
Jul 17, 2006 12:14 PM
