Idle up,down,up,down
Old May 6, 2008 | 11:16 PM
DAN POUCHER's Avatar
!!!!!!!!!!! Help !!!!!!!!!!!!!!!!
I have a problem with my 2000 dodge ram 2500 diesel. about a month ago I was on the way home and the truck started idling between 600rpm to 900 rpm up and down up and down when I let off the throttle so I went home and checked the codes listed in the odometer (cycle key 3 times fast) it listed a 1695 and then listed the code for a defective TPS (throttle position sensor) and it had a bad oil sending unit code so I went to the dealer and purchased a new TPS ($450.00) and a oil sending unit ($358.00) and came home and put them on , After starting the truck it was idling good so I took it for a drive, I drove it for about 20 min then it started doing it again so I went back home and did a code check on it again and it listed 1695 and that was all. The truck does not completly die it can still be drove but you have to keep your foot on the gas.It seems the longer you drive it the worse it gets. A little history on what I have done to the truck in the last year. My truck has 120,000 miles on it before the warrenty went out I was having problems with the fuel system and the dealer replaced the lift pump with a new in the tank fuel lift pump. and about 6 months after the warrenty went out the injection pump went out so I went to diesel pump injection services and purchased a new rebuilt pump ($1250.00). I have also ran a fuel pressure check at the injection pump to make sure that the lift pump is not starving the injsction pump once it get warm, It is running 7 Lbs and is not geting worse than that even if truck is idling bad . I am running out of Ideas on what to do , A friend suggested the following , crank sensor,mass flow sensor,ecm. If anyone has any suggestions or has had this problem that can help I would appriciate the help
Thanks
Dan Poucher
Old May 7, 2008 | 02:13 AM
cumminspower79's Avatar
Im assuming thats 7 psi idling at the pump, because under a load that might be a different story. Most like to see 13 to 15 at the pump at idle and 10 to 12 at WOT. Just a thought.
Old May 7, 2008 | 07:23 AM
Chris Taylor's Avatar
Get Gauges. At least a Fuel pressure gauge. I had 14 at idle but driving was dipping into the 2-4 range. A change of the filter solved that issue. If you have 7 at idle that could be the problem. I got the same TPS code on mine.
DAN POUCHER
Jun 14, 2008 06:52 PM
pet05
Oct 5, 2006 11:02 AM
rdc
26
Jul 31, 2006 09:17 AM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
