100% cat full regeneration
Old Oct 16, 2007 | 03:59 PM
KMKDiesel's Avatar
Exclamation 100% cat full regeneration
I have been running strait piped for some time now. I am going to put the cat and dpf back on tonight or tomorrow and was wondering if anyone has strait piped theres thru codes and then put the stock stuff back on and it kicked back into regeneration and cleared everything up on the overhead said saying that nothing was wrong. Anyone that has tried this what happened. Thank you
Old Oct 16, 2007 | 04:27 PM
humboldt's Avatar
Once the motor is detuned, I'm pretty sure you have to go into the dealer to clear the code and then it will be able to regen again. I haven't straight piped, but I did clog the dpf and the motor detuned until the dealer fixed it.
Old Oct 16, 2007 | 04:44 PM
KMKDiesel's Avatar
Do you know what the dealer did to it.
Old Oct 16, 2007 | 04:53 PM
humboldt's Avatar
I can look up the repair tag at home but I think they cleared the code and then did a manual regen by driving it 45 minutes on the highway. If you have something that can clear the code, you would probably be back regular operation if it senses everythings ok with the exhaust.
Old Oct 16, 2007 | 05:26 PM
KMKDiesel's Avatar
The only thing I am worried about is when I clear the codes they come right back on and when the dealer did the latest flash it didnt clear them either. Have any you had the dealer make it go into regen to clear it out with there scanner
Old Oct 16, 2007 | 10:20 PM
KMKDiesel's Avatar
Anyone else
Old Oct 18, 2007 | 08:46 AM
fflarry's Avatar
The power pup has a setting for manual regen anytime you need it, and it will read and clear the codes for you.
Old Oct 18, 2007 | 01:48 PM
KMKDiesel's Avatar
I talked to my dealer and tomorrow when I get my new sensor in that I screwed up they are just going to hook there scanner up and let my take it and put in in manual regeneration.
Old Oct 18, 2007 | 09:46 PM
Cummins610's Avatar
Nice Dealer
Old Oct 19, 2007 | 01:52 PM
KMKDiesel's Avatar
K guys just got back from the dealer have to head back in a few minuets (1 mile away) I took there starscan and it would not go into a manual regen and the codes will not clear still. We made sure it had the latest flash which we thought it did but there is another au flash that it put in. Still didnt help at all. Have any of you seen this codes wont clear and manual regen wont work.
13bdarren
Jan 27, 2009 12:39 PM
Outwest
Mar 11, 2008 05:41 AM
West Coast
Jul 4, 2007 10:25 AM
Kampnnut
Apr 10, 2007 08:22 AM
79warlock
Mar 15, 2007 06:02 AM
