will not start
will not start
yesterday i was driving in town. i went to turn on a street and gave it the pedal and there was no power then i pulled into this place to get somethin to eat and when i came out the truck wouldnt start i would just turn over. it would start up and die right away. anybody have any idea
Just take your rig to a good reputable dealer and you shouldn't have any issues.
if you are having intermittent power loss issues, the lp is causing them, the cp3(your injection pump) cannot suck through a dead pump, and provide the 23,000+psi fuel to the injectors to produce the normal amount of power.
My lp was coming and going for 3 days, and i would get power loss, and no starts sometimes. i opted NOT to get the intank, and went aftermarket at my expense.
Most would consider the in-tank LP an upgrade to what you have(or had). it will not affect performance adversely, and it should be in service for much longer thean the filter mounted lift pump.
The dealer is not trying to rip you off or screw you. He is fixing your problem with a better solution than just replacing what you had.
TXJClark
Dec 6, 2014 05:50 AM
Hunky Dory
May 13, 2013 08:09 PM
FirstGen1991
Dec 22, 2012 04:24 PM
CoolumConst
Oct 11, 2008 10:00 PM
