Why Such a Small Turbo on 3rd gen?
Old Jan 8, 2004 | 10:54 AM
TXTad's Avatar
My 2002 HO has a 16 cm^2 turbo to make it's 245 HP. Why did Dodge (Cummins?) go to such a teeny turbo as a 9 or 10 (whichever it is) cm^2 to do 300+ HP?
If I'm not going to bomb, is there any downside to the smaller turbo?
Thanks,
Tad
Old Jan 8, 2004 | 11:52 AM
RamDan03's Avatar
A smaller turbo usually spools up at lower RPMs and is more efficient.
The only disadvantage is if you are trying to make big HP, the small turbo will limit you in terms of power and EGTs/
Old Jan 8, 2004 | 02:18 PM
SBENNETTLAWN's Avatar
What are the options for a bigger turbo on 3rd gens? AND IS IT ALOT OF WORK TO CHANGE? CAN THE WASTE-GATE BE ADJUSTED TO GIVE MORE BOOST?.
Old Jan 8, 2004 | 02:42 PM
RamDan03's Avatar
There are a few companies that offer turbo upgrades. The boost can be adjusted with a "boost elbow."
Check out www.dieseldynamics.com
Old Jan 8, 2004 | 04:55 PM
hog head's Avatar
new too this site,in joying it a lot
Old Jan 8, 2004 | 06:44 PM
I LOOKED AT DIESEL DYNAMICS AND DIDN'T SEE THAT ELBOW, BUT I E-MAILED THEM . THANKS.
Old Jan 8, 2004 | 11:04 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re: Why Such a Small Turbo on 3rd gen?
Originally posted by TXTad
1) My 2002 HO has a 16 cm^2 turbo to make it's 245 HP. Why did Dodge (Cummins?) go to such a teeny turbo as a 9 or 10 (whichever it is) cm^2 to do 300+ HP?
2) If I'm not going to bomb, is there any downside to the smaller turbo?
1) Actually your 02 had a 12cm turbine housing on an HX35 compressor. Definitely a bit larger turbo, probably too big for the 245 horspower, since we were able to generate 340 - 350 relatively efficiently with the HX35/12
2) No. The HY35/9 on these trucks is very well matched to the power. Free up the air a bit to stop starvation, and you've got a well tuned truck.
Rod
Old Jan 11, 2004 | 04:56 AM
PourinDiesel's Avatar
Rod,
ISB's were a different animal than the 3rd Gens.
With higher injection pressures these days, you can utilize more of the fuel for making power.
--Justin
Old Jan 11, 2004 | 09:38 AM
Push Rod's Avatar
Oh for sure, but they still could have easily gotten away with a HY35/9 on the 245 engine. Even allowing 4 more PSI (to a max of 22) would have kept the HY _well_ within its MAP, and made for a more efficient engine.
Its a good thing they didn't do that though, otherwise the turbo would have needed replacing earlier
Rod
CruisingRam
Jan 19, 2012 04:45 PM
sgrooms
21
Apr 8, 2008 11:17 AM
arroyojim
Sep 23, 2006 12:05 PM
chaos24valve
Jun 26, 2006 09:29 PM
BGDUMMY
May 9, 2003 06:59 PM
