Why this fault code??
Old Mar 29, 2007 | 08:57 PM
O.T's Avatar
O.T
hey can someone shed some light on what I'm to search for with a P 2509 code.
onetun
Old Mar 29, 2007 | 10:37 PM
vzdude's Avatar
DTR's 'Go to Guy'
P2509-POWERDOWN DATA LOST ERROR
For a complete wiring diagram Refer to Section 8W.
When Monitored:
Continuous - key on or key off.
Set Condition:
Loss of voltage detected at the ECM for a calibrated amount of time.
Possible Causes
POOR CONNECTIONS AT THE BATTERIES
LOW BATTERY VOLTAGE
OPEN FUSED B+ TO ECM
OPEN GROUND CIRCUIT
BATTERY + SHORTED TO OTHER CIRCUITS
RETURN CIRCUIT SHORTED
BATTERY + SHORTED TO GROUND
INTERMITTENT CONDITION
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
Diagnostic Test
1. POOR CONNECTIONS AT THE BATTERIES
Visually inspect the wiring at the battery for damaged wires, or corrosion.
Are the connections tight and free of corrosion?
Yes
Go To 2
No
Repair the poor connections at the batteries.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES/ENGINE CONTROL MODULE - DIAGNOSIS AND TESTING)
2. LOW BATTERY VOLTAGE
Measure the voltage between the positive and negative posts of the batteries.
Is the battery voltages both above 12 volts?
Yes
Go To 3
No
Recharge or replace the battery (s).
3. OPEN FUSED B+ TO ECM
Turn the ignition off.
Disconnect the ECM harness connectors.
Turn the ignition on.
Measure the resistance between the positive battery post and the ECM supply circuits.
Is the resistance less than 10 Ohms?
Yes
Go To 4
No
Repair the open fused B+ circuit to ECM.
4. OPEN GROUND CIRCUIT
Measure the resistance between the negative battery post and the ECM ground circuits.
Yes
Go To 5
No
Repair the open ground circuit.
5. BATTERY + SHORTED TO OTHER CIRCUITS
Measure the resistance between the ECM supply circuits and all other circuits in the ECM harness connector, except other supply circuits.
Is the resistance greater than 100k Ohms?
Yes
Go To 6
No
Repair the battery circuit short to other circuits in engine harness.
6. RETURN CIRCUIT SHORTED
Measure the resistance between the ECM return circuits and all other circuits in the ECM harness connector, except other return circuits.
Yes
Go To 7
No
Repair or replace the engine harness.
7. BATTERY + SHORTED TO GROUND
Measure the resistance between the ECM B+ supply circuits and ground.
Yes
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
No
Repair Battery + shorted to ground.
Old Mar 29, 2007 | 11:36 PM
br6ad's Avatar
nice
Wow, now that is a nice troubleshooting guide. My truck had the 2509 code at around 4000 miles. it went away after 2 days. I actually had an appointment with the dealer the day it went out. I never went since they would have needed to see the light to do anything about it.
Thanks for that info
Old Mar 30, 2007 | 06:14 AM
vzdude's Avatar
DTR's 'Go to Guy'
Came staight from Daimler! Hope it helps you out!
Andy
sgrooms
21
Apr 8, 2008 11:17 AM
DuaneWKKC
Jul 26, 2006 12:25 PM
flathead
Jul 17, 2005 12:03 AM
powerchokeater
Apr 13, 2005 08:36 AM
MB
Oct 22, 2003 08:01 AM
