Possible hub bearing failure
Old Feb 25, 2007 | 11:44 PM
megaOX's Avatar
Has anyone run into a frt hub bearing failure yet on there Megacab? I have an 06 with 41k. My rgt frt is making a clicking noise at slow speeds and pretty noticable roaring at hwy speeds. By the way it is 4wd. Any help on this would be great.
Thanks
megaOX.
Old Feb 26, 2007 | 12:15 AM
JRG's Avatar
JRG
I had one replaced on my 03 @ about 25k. I don't think the 03 and 06 use much different front ends.
After a trip down the hwy, feel the wheel/rim, if it is hotter than the other side its a good indication of your problem.
JRG
Old Feb 26, 2007 | 04:15 AM
Road Traveler's Avatar
Yeah sounds like a wheel bearing!! I have gone through 3 sets!!! Wish they would put a grease zert so you could add some grease. With the weight those front ends carry plus the heat sink they get from the rotors the grease just cooks out of them! But dodge says they are a sealed lifetime bearing that never needs grease!! yeah right!!
Old Feb 26, 2007 | 11:17 PM
megaOX's Avatar
Thank you guys. I figured that is what my problem is. Do you know if it is covered by the 7/70 warr that Dodge has? If not how much does the hub hit the pocket book for?
Old Feb 26, 2007 | 11:20 PM
It should be! but I dont have any experience with it all my probs come after warranty but after a few months I was out of warranty HAHA!!!
When I bought my first hub it was $600 over the counter each. Then about 6 months ago I got them just a tad under $300 each and they were in stock the first ones I got I had to order and wait almost a week to get them!
Old Feb 27, 2007 | 09:12 AM
dezeldog's Avatar
Anybody needing the front hub assembly might wanna look here....www.ebatmus.com. $214 and change. Part # BR930502.
Jim
Old Feb 27, 2007 | 12:09 PM
Jim
Hey thanks for that! Always looking for places that will keep my parts cost down!!
Old Feb 27, 2007 | 02:17 PM
dezeldog's Avatar
Notta a problem traveler. Just glad I could save ya a couple $$.
Jim
Old Feb 27, 2007 | 02:20 PM
gullydog's Avatar
did mine at 40kms
Old Feb 27, 2007 | 02:27 PM
Yeah a few bucks is a few bucks! After all the goodies I have had to buy it makes a big deal!
Old Feb 27, 2007 | 04:56 PM
BUSAHAULER's Avatar
When Mine Clicked It Ended Up Being A U Joint But That Was After They Replaced The Bearing Under Warrty. That Was At 69000 Miles
Old Mar 2, 2007 | 10:37 AM
bigsam's Avatar
My hub bearings are shot
Mine just wen to the shop this morning, both hub bearing need replaced. My dealer said these are NOT covered under 7\70 warranty . $1100 to replace both!
Old Mar 2, 2007 | 10:45 AM
WOW that is high!! well I have changed mine several times!! You can get the bearings for right around $600 dodge cost and if you can change a tire and do a brake job you can change your hub!!!!
Old Mar 2, 2007 | 12:53 PM
Boz007's Avatar
Why in the world have you not gone to a manual hub setup? With as much as you drive it would benefit you alot.
Old Mar 2, 2007 | 01:34 PM
Highway 4x4's Avatar
Why are these bearings going out? Is there a common factor that is causing it? Big tires, deep water, salt spray, snow plows? These are suppose to be good bearing design and hold up well fore some. I have 3 years and 50K and am getting nervous reading about failures of bearings and ball joints. I am all stock and nothing gets wet in So Cal.
