When to change anti-freeze?
Old 08-09-2009, 10:04 PM
FastTaco's Avatar
Got about 70k on the clock now. Fluid is still nice and red/clean looking. Motor runs about 195 deg in summer. Should it be ok for a while?
Old 08-09-2009, 10:16 PM
NickBeek's Avatar
I just did mine about a month ago @ 100K miles. It came out pristine. I drained, refilled with distilled water, ran up to operating temp, drained, refilled with DW again, ran up to operating temp again, drained, and added straight coolant to get to a 50 / 50 mix with the distilled water. Then topped it off with a 50 / 50 mix of coolant and DW. A little hint, if you take the heater hose off at the head it will vent the system nicely and make refill a lot easier. After a using this method I drive it normally and then added about a quart of 50/50 mix. It has been holding it's level since then so all the air is out I guess. While I had it drained I replaced the little short piece of hose behind the turbo with an updated part and spring clamps that I got at the dealer. Hopefully this new hose and clamps will cure the fall leaks that happened every year.
This is the hose I was talking about
Here is the replacement hose
And clamps
Here it is installed
Old 08-09-2009, 10:47 PM
tryNto's Avatar
I think 5 years or 100k is what is good for the change interval
Old 08-09-2009, 10:57 PM
FastTaco's Avatar
Thanks guys. I've already double clamped my hose as it has leaked twice since new.
Old 08-10-2009, 07:10 AM
MikeyB's Avatar
Planning to drain the coolant this fall. Going on 7 years now but still looks good.
Nick, good idea about opening up one of the coolant ports on top of the head for venting.
MikeyB
Old 08-10-2009, 09:45 AM
Nate-03 D's Avatar
What coolant are you going to run?
Old 08-10-2009, 12:55 PM
Devinraptor's Avatar
And clamps
Does anyone know where you can buy this online or do you have to go to the dealer?
Old 08-10-2009, 06:51 PM
NickBeek's Avatar
Those parts are from Cummins, so you could go to a Cummins dealer and get them I'm sure. I think they were about $20 +/-.
BTW, I used the Zerex G05 H.O.A.T. coolant. I got it at NAPA for about $11 / gallon.
Old 08-10-2009, 08:11 PM
trik396's Avatar
NickBeek, how much distilled water and how much coolant are we talking about here?
Old 08-10-2009, 09:02 PM
1985cucv's Avatar
i was wondering how do you still tell if its good? or can you add an additive to get it back to normal? thanks
Old 08-11-2009, 06:55 PM
NickBeek's Avatar
I'm going from memory here...... I believe the total system capacity is 7.375 gallons. So I bought 4 gallons of straight coolant (there is some left over) and I ended up using 16 or so gallons of DW. When I drained the system I got about 5+ gallons out. I used DW to flush with and then used it for final fill along with the coolant of coarse.
Old 08-12-2009, 12:05 PM
DTR 1st Sergeant
soulezoo's Avatar
Another good time to change is when your rear freeze plug blows out halfway down the track...
Old 08-12-2009, 12:54 PM
TexasCTD's Avatar
You sound like a man who speaks with experience.
Old 08-12-2009, 05:21 PM
trik396's Avatar
someone here posted a pic taken as the truck was going down the track (side view) just as the plug let go. You could even see the plug, if I remember correctly... anyone remember that pic???
Old 08-12-2009, 05:25 PM
MikeyB's Avatar
Yeah, that was John's (RamWheelsBy4) truck.
MikeyB
Quick Reply: When to change anti-freeze?
