whats wrong with pennzoil
Old Feb 25, 2007 | 06:54 PM
singleturnout's Avatar
just wondering why everybody bashes it when its made by Shell just like the rotella we all use.
Old Feb 25, 2007 | 07:15 PM
Arkapigdiesel's Avatar
Pennzoil isn't bad.....here is some real data in which Dallas based trucking company Stevens Transport used the Pennzoil 15W-40 in extended service.
PoorMansCat's Avatar
You ask whats wrong with Penzoil?.... They sponsor Kevin "the cry baby" Harvick!!.. hahaha..JK!
Old Feb 25, 2007 | 08:57 PM
bluebull's Avatar
Nothings wrong with it. Just not as popular on these boards as others.
Old Feb 25, 2007 | 09:02 PM
BRET LIVELY's Avatar
If You Want Tar Based Biuld Ups In Your Engine Then Use It ..
Try Valvoline
Old Feb 25, 2007 | 09:13 PM
Try Valvoline
You have proof of that? Please provide a link that proves that one API certified oil promotes sludge moreso than other oils.
Old Feb 25, 2007 | 10:21 PM
AEmedic's Avatar
Pennzoil is a paraffin based oil and while I have nothing against Pennzoil, I will NEVER use a wax based oil which is what Pennzoil is!
Old Feb 25, 2007 | 11:30 PM
JRG's Avatar
JRG
Amen. It seems to me that Pennzoil is the only oil that you hear of this sort of thing. When I hear of a long time user pulling off a valve cover and finding HUGE build up, its enough for me not to take a chance. In Pennzoil's defense, that motor had tons of miles on it, although it was pre '80s tight tolerances.
JRG
Old Feb 26, 2007 | 04:25 AM
Road Traveler's Avatar
Well it is the age old battle with pennzoil!!
I know back when I was more up on the refineries and things of the sort PENN oil refineries were about 10-15 years ahead of everyone else. They had some of the best additives for there oil. In the old days they did have some pretty bad oil and you would pop off valve covers and find that cacky sludge build up that people talk about. But they say the new oils are much different!
Like an old time mechanic told me if it makes you feel better to use a specefic brand knock your socks off and use it. Just as long as you change it regular and keep a good oil filter in there the motor is going to last just that simple. Now there are oils that offer some benefits out there because of the additives they put in but to each there own. Just change it often and you will be fine.
I worked for Caterpillar for years and we never had a problem with Rotella, Delo 15w-40 or Mystic 15w-50 and these engines were always pushed to far and always in the most nasty conditions possible!
Old Feb 26, 2007 | 10:17 AM
Good gravy.....paraffin based doesn't equate to wax.
One of the well respected HDEO oil lines out there is Schaeffer's. Their Supreme 7000 series 15W-40 uses a paraffin based base stock along with a Group III hydrocracked base stock (semi syn).
Before you start to talk out of the side of your mouth, you may want to take a peek at the thousands of UOA's that Schaeffer's has in diesel pickups and OTR trucks. Schaeffer's is well known for its' properly formulated oils and the stellar UOA's that they produce.
Here are some Schaeffer's UOA's in heavy duty applications for ya'll to look at, just in case you don't believe me.
Old Feb 26, 2007 | 01:14 PM
Well you know how it goes!!! Some people will never change there thinking!
Old Feb 26, 2007 | 02:19 PM
fordracing19's Avatar
As long as you use the correct weight and api cert is doesnt matter on brand it you keep it changed. We have a small fleet of F150's that have had nothing but Pennzoil in them and changed at 3-5k miles. Some of the trucks are over 300k and never had a valve cover/oil pan off of them.
Old Feb 26, 2007 | 02:25 PM
Yeap keeping it changed is the main thing!!
Old Feb 26, 2007 | 05:59 PM
JRG's Avatar
JRG
I agree 100% that if you keep most any oil changed/filtered you will be fine.
As I see it though, once a company has a reputation for less than stellar conditions, there is FAR too many other quality choices out there.
JRG
Old Feb 26, 2007 | 06:08 PM
JRG
Yeap and if it makes a person feel better by running a certain type then by all means knock yourself out!!
hobbes2
18
Apr 4, 2005 10:01 PM
doubledodge2003
Mar 6, 2005 02:18 AM
MikeyB
Jul 17, 2004 02:11 PM
n5oxp
15
Jul 4, 2004 07:21 PM
rossn2
Mar 31, 2004 01:02 PM
