What type of Grease?
Old Feb 22, 2007 | 07:59 PM
CUM4X4MINS's Avatar
Question What type of Grease?
What type of Grease do you guys use to lube the Driveshaft and Tie rod ends? Did a search and couldn't find anything thanks for the help!
Michael
Old Feb 22, 2007 | 10:29 PM
danc46's Avatar
I've used JT6 on tractors, trailers, and vehicles for years and never had a problem.
Old Feb 22, 2007 | 11:13 PM
torquefan's Avatar
The most common grease used is an NLGI-2 rated chassis/wheel bearing grease.
Old Feb 22, 2007 | 11:47 PM
CUM4X4MINS's Avatar
Thanks for the imput guys
Michael
Old Feb 23, 2007 | 03:00 PM
el toro's Avatar
My owners manual says lithium based grease.
Old Feb 23, 2007 | 05:00 PM
elkman12's Avatar
strange??? my manual said use NLGI lub. could not find Lithium.
06 4X4 std cab
Old Feb 23, 2007 | 05:08 PM
djbikeman's Avatar
Lithium Grease is used in the driveshaft. At least that is what the sticker under the hood of mine says. I use chassis/wheel bearing grease in the tierod ends.
Old Feb 23, 2007 | 06:04 PM
CUM4X4MINS's Avatar
I saw the sticker under the hood today. Would the Lithium grease used on the driveshaft be fine to use on the tie rod ends ya think?
Michael
Old Feb 23, 2007 | 07:20 PM
djbikeman's Avatar
Lithium grease can get pretty thin, especially when heated. I don't think the seals in the tie rods would hold the lithium grease very long. That's just an opinion. I have no actual evidence to support that.
Old Feb 23, 2007 | 07:42 PM
CUM4X4MINS's Avatar
Alright Thanks for the help.
Old Feb 23, 2007 | 10:02 PM
D-Roc's Avatar
I use the Amsoil Heavy Duty with Moly
Old Feb 24, 2007 | 10:19 AM
Oilguy's Avatar
Lithium is junk... Water and heat will kill it very fast... Get an aluminum complex grease... I use Schaeffer with Moly... I think the product number is #229 >>> Many times the staying power... Much higher temp range.... Will not wash out .... Much Much Higher film strength and doesn't cost much more than you are paying for Lithium.
Oilguy
Old Feb 24, 2007 | 12:28 PM
Arkapigdiesel's Avatar
Ditto on the Schaeffer's aluminum complex grease. Schaeffer's has the best grease on the market IMO.
Old Feb 24, 2007 | 01:47 PM
DaveB.inVa's Avatar
So are you using the Schaeffers for both the tie rod ends and the driveshaft?
Old Feb 24, 2007 | 02:35 PM
I put Schaeffer's grease in every alemite/zerk that I own.
Mexstan
May 22, 2015 06:46 PM
Forty-Two
Oct 22, 2008 11:55 PM
kram
Aug 29, 2007 11:01 AM
May 5, 2003 05:40 AM
TXTad
Oct 21, 2002 09:25 PM
