What are signs of an injector going bad?
Old Dec 13, 2013 | 05:30 PM
  #46
AH64ID's Avatar
Glad Todd is hooking you up.
Old Dec 13, 2013 | 10:12 PM
  #47
RobG's Avatar
Thanks! It's a relief knowing I'll have parts here probably by Tuesday or Wednesday.
Speaking of -- the FCA is an easy swap. What about the PRV? I'm guessing it's that thing on the end of the fuel rail, up underneath the cowling? How does it come off, what with that line coming out of it?
Rob
Old Dec 13, 2013 | 10:29 PM
  #48
AH64ID's Avatar
I haven't ever removed one, but I believe you remove the banjo holding the return down, then remove the PRV and reverse. I think it's a simple job. If the torque spec's aren't in the box give Todd a call back.
Old Dec 16, 2013 | 09:26 PM
  #49
RobG's Avatar
BTW -- do I have to depressurize the system before trying to remove it? I would imagine there's a bit of fuel pressure built up in there, even if it's leaking down.
Parts are here.. I pick them up in the morning. Good thing too, since the idle is getting much worse. I'm to the point of worrying if it'll continue running.
Rob
Old Dec 16, 2013 | 10:01 PM
  #50
AH64ID's Avatar
Let it sit for a minute and pressure will discipate.
Old Dec 17, 2013 | 01:50 PM
  #51
RobG's Avatar
IT'S ALIVE!!!
And not a moment too soon. It nearly didn't start this morning just to go pick up the parts.
The replacement was super easy. It doesn't get much easier than that. I think I spent 15 minutes on both items. Then, with fingers crossed, I attempted to start it. I expected it to crank for a bit since pressure had fallen off. But nope, it fired right up like it's old self!
I went for a short drive down the street and back, and there's no more bouncing idle, and no more hesitation when shifting and rolling onto the throttle again -- something I hadn't realized was even a problem. That tells me these things have been going bad for a while now.
Yay!! Thanks a ton for all the help!
Rob
Old Dec 17, 2013 | 02:11 PM
  #52
AH64ID's Avatar
Great to hear!!
Old Dec 17, 2013 | 10:08 PM
  #53
RobG's Avatar
Okay so one more question, not related though. I'm doing balljoints starting on Friday most likely. I have all the tools located and a shop to work in. The video I saw makes it look fairly straightforward.
I plan to do the U-joints on the ends of the axles too, since I have the whole thing apart. I could get Spicers, which I know are good, for $72-ish each (ouch). I could get whatever Carquest sells for $55 each, or I could get AutoZone's Duralast Gold for $22 each.
Seeing as how I'm seriously broke, I'm considering the $22 ones. I don't see how they could be any worse than OEM. I wish I had the cash to do the Spicers, but I really don't.
Thoughts?
Rob
Old Dec 18, 2013 | 07:47 AM
  #54
AH64ID's Avatar
OEM is actually pretty good, so it would be easy to be worse than OEM.
I recall all of the shops I talked to about u-joints recommending the AAM's, best in terms of reliability and longevity.
Greasable joints are actually weaker than non-greasable.
Old Dec 18, 2013 | 01:23 PM
  #55
RobG's Avatar
AAM... is that the brand? I'll have to look 'em up
Rob
Old Dec 18, 2013 | 01:28 PM
  #56
AH64ID's Avatar
Yes AAM.
Old Dec 18, 2013 | 07:16 PM
  #57
RobG's Avatar
Sweet, thanks. Found a set on eBay for $55/ea and ordered them this morning. Much more tolerable price.
Old Mar 6, 2018 | 06:56 PM
  #58
Coty Dedmon's Avatar
I have a 5 9 that Lopes eight or nine times after starting and then dies any suggestion could the injector pump be bad?
Capp35
Sep 15, 2011 01:21 PM
mstep3
Jan 22, 2011 10:24 PM
kycurs
Jul 22, 2006 07:13 PM
MJDiesel
Nov 29, 2005 04:56 PM
TE-44
19
Oct 29, 2003 04:23 PM
