What coolant are you using?
Old Apr 15, 2013 | 11:21 PM
sallyman1's Avatar
What coolant are you using? Long life or green stuff?do u mix either with distilled wąter? How often do u flush coolant system if using mopar long life?is a. Coolant filter bypass worth it?
Old Apr 16, 2013 | 12:01 AM
Guardrail's Avatar
I use Peak global with hoat additive. It's an extended life, so I change ever 100,000 miles. No need for a flush if it's clean coming out.
I always get the 50/50 mix on sale. It's just as cheap.
Semi trucks don't even use the filter any more, so it's a waste if you ask me.
Guardrail
Old Apr 16, 2013 | 06:36 AM
papaduck's Avatar
The manuals call for HOAT. Do not mix with other coolants and dilute to 50/50 with distilled water. Change at 5 years or 100k miles.
Zerex GO-5 can be had at NAPA.
Old Apr 16, 2013 | 08:37 AM
madhat's Avatar
Administrator/Jarhead
What papaduck said. The coolant Dodge requires is made for a reason, it will save you trouble down the line. HOAT, either the MOPAR or Zerex. It's 100k coolant, so don't waste your money on anything else.
Old Apr 16, 2013 | 09:37 AM
Dr.Dizzle's Avatar
The total cooling system capacity is 7.4 gallons, so if your flushing you need 3.7 gallons of G-05. If your just draining and filling you only need about 2-2.5 gallons of G05. Use distilled water to flush the system and also to dilute the coolant concentrate. You can use Valvoline Zerex G-05 HOAT coolant. The NAPA part # is ZXG051. Another is the factory fill Mopar 5 Year/100,000 Mile with (HOAT) Embittered available at dealerships. Also,the Ford / Motorcraft Premium Gold Engine Coolant - part number and CVC-7-B (Canada). They are HOAT formulated G-05 coolants.
Filtration is never a bad idea no matter what. However, that is up to you to decide if it's worth the costs associated with doing so.
Old Apr 16, 2013 | 09:48 AM
sallyman1's Avatar
thanks. all great answers. i have about 65,000 km on my longlife chrysler coolant and or about 4 years. i might just drain some from bottom rad hose and top off. thanks
Old Apr 16, 2013 | 06:03 PM
DodgeDiesel61's Avatar
Zerek is also available at your local CarQuest
Old Apr 16, 2013 | 08:46 PM
C Schomer's Avatar
Fleetguard recommends ES Complete blue. I've been using it in CTDs since my 97. I keep the additives up with DCA and that also keeps Ph up. They say I will never have to change it as long as I use the DCA. Craig
Old Apr 19, 2013 | 04:12 AM
BothellDiesel's Avatar
Rotella ELC is good stuff
cutthroatxxx
17
May 22, 2015 07:09 AM
rammike
Sep 6, 2012 10:54 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
