What Clutch to go with for a NV5600???
Hello All, I'm approaching the 100,000 mile mark and my tranny is having the typical rough shifting of a NV5600. I just changed out the fluid with Penzoil Synchromesh and overfilled by 1 qt. It seemed to have helped but I really think I'm on the verge of a new clutch. The truck was used for pulling cattle trailers when it was on the newer side but is just used for going around town and driving cross country now. I have read good things about the south bend clutches but I really don't think that i need to drop the money in one. I plan on getting a quadzilla mileage max and plan on upgrading my Lift Pump eventually as I'm still on the stock pump and I already have a AEM Brute force Installed. Not really looking to go crazy on upgrades so I was wondering if anyone has any suggestions for a reasonably priced clutch that is good maybe up to 350 to 400 horsepower or should I go with a South bend? Should I look into replacing the flywheel or just see if I can get it trued up at the machine shop? Just want to cover all my basis because it's a pretty big job to do and then have to go back in and do it again because I should have used this or done that. Thanks
http://www.southbendclutch.com/1947cono.html
This would be a good clutch to replace your old one, and should last you much longer.
A number of the manufactures that make clutch's like Zoom have setups for these trucks that are stronger then stock(not a whole lot but stronger)at decent prices.Search the web.Stick with a name brand.
I have no experience with other clutches, but the Con O and Con OFE from South Bend would be good choices for holding power and smooth driving. The OFE might have a slight bit of grabbiness to it, but it's nothing like an FE.
Justin
Justin
The last clutch i did for a guy, he didnt want to drop much dough so i called dial-a-clutch and bought a ceramic button disc (175$ approx) had the local napa turn the flywheel for 35$, 40$ throwout and pilot bearig and used the old pressure plate. He says it is still working great a year later. As long as you have not been slipping the clutch the pp should not need to be relaced. You can look up www.dialaclutch.com.
dodgezilla04
13
Dec 4, 2006 10:13 AM
bhuffstutter
0
Oct 17, 2005 09:41 PM
fishin fever
Nov 29, 2003 11:29 AM
