weak lift pump 2003 cummins
Old Jul 18, 2010 | 08:46 PM
w63's Avatar
w63
I installed a 3 micron filtre system from bd power and the 5 psi low fuel protection light While driving around all is good until I pulled my boat . now the light gives a quick blink when I throttle up.Added a gauge to the system and found I,m only getting 10 to 11 psi while idling or driving. When I step on it pressure drops to 5 psi for a second.Does anyone know what the lift pump in the tank pushes(psi) and whats the best fix?? Any suggestions would be great
Old Jul 18, 2010 | 10:44 PM
madhat's Avatar
Administrator/Jarhead
Man, the best fix is to get rid if that crappy little pump and get an Air Dog or Raptor...
As long as you have positive pressure at WOT, you'll be ok, just keep an eye on that fuel pressure. That pump runs at a steady flow the whole time, so you're not straining the lift pump by making the pressure drop.
Old Jul 19, 2010 | 01:18 AM
tryNto's Avatar
Those #s are fine...
Old Jul 19, 2010 | 01:20 PM
El Borrego's Avatar
If it's the original lift pump you can find exact replacement but I wouldn't use it. I had an in-tank pump put in when my original pump crapped out. Bad design by Dodge (Cummins didn't like it but couldn't get dodge to change). A lift pump should have a short lift and a longer push. Orig equip was just the opposite.
Old Jul 19, 2010 | 05:31 PM
w63's Avatar
w63
I,m hoping I can leave my original lift pump in the tank and install a pump on the frame to help out if thats possible and use the 2 pumps.
Old Jul 19, 2010 | 05:35 PM
madhat's Avatar
I would not. The OEM pumps are not a flow through design, and if the OEM pump takes a crap, the second pump won't be able to get fuel through it.
Why would you want to do that anyway?
The aftermarket pumps flow plenty on their own.
Old Jul 19, 2010 | 06:16 PM
Dr.Dizzle's Avatar
I agree! A Raptor along the frame would be a good solution.
Old Jul 19, 2010 | 08:07 PM
w63's Avatar
w63
I ordered a flow max lift pump for on the frame rail and retro kit for in the tank with 5 yr warranty out of Abbotsford Looked at raptor but In need it by wed so time is a issue. Think I will just cut a access hole in the box instead of dropping the fuel tank this should make things easier for now and future.
Old Jul 25, 2010 | 03:18 PM
w63's Avatar
w63
3 hrs to install new frame rail pump and strainer no more light coming on alls kinda good.At a stop sign sometimes when I step on the pedal it hesitates but not all the time anyone have any ideas ? Whats next
Old Jul 26, 2010 | 09:20 PM
BLACKBEAR's Avatar
Your pump is mounted next to your oil filter. You can get one from www.genosgarage.com For 180.00 If you get any of the other pumps it will cost you some good money.
Old Jul 26, 2010 | 11:47 PM
madhat's Avatar
Huh? Next to the oil filter? I've never seen that...
On the 03's to 04.5's, the lift pump was mounted on the fuel filter canister.
Get a pusher pump, your choice, and remove the canister mounted pump.
Call me if you have questions. I've done a lot of these. Just remember I'm on the west coast, don't call me at 7 east coast time.
Old Jul 27, 2010 | 07:10 PM
w63's Avatar
w63
I mounted this one next to my fuel filtre on the frame.mech looked at today and it ran fine for him he,s going to heat it up more tommorrow and hopefully it hesitates for him.
crewcabxlt
Apr 3, 2009 06:31 PM
dj_souvlaki
Feb 27, 2008 06:46 PM
mopar2ya
Aug 26, 2004 12:23 AM
crobtex
May 2, 2004 07:35 PM
