waste gate
Old Jun 23, 2003 | 09:54 PM
03dodgeram's Avatar
waste gate
i tried adjusting my waste gate on my 03 ho and the rod would not turn. so i shimmed the acctuator (however you spell it) out about 1/16" to start and it made a HUGE diffrence. it put me from 22psi of boost to 26. i want to shim it out a little more tommorrow and see what that does. 4psi make a huge diffrence. does anyone know what the limit is with the stock computer? ive heard everything from 30 to 35.(hopefully 35)
Old Jun 27, 2003 | 09:29 PM
03quadduallyho's Avatar
Re:waste gate
OK, this is interesting stuff. Please send pictures or a detailed explanation on where it is and how you did it!<br><br>Thanks Monte
Old Jun 27, 2003 | 09:32 PM
phox_mulder's Avatar
Re:waste gate
I'm interested as well.<br><br>Don't the 03's come with the same HY35 that my '02 auto tranny CTD comes with?<br>(or is that the HX, I always get them confused)<br><br>Do they incorporate the same wastegate as well?<br><br><br>phox
Old Jun 29, 2003 | 09:18 PM
Re:waste gate
Doesn't seem like anyone is interested in giving us some insite, OK I'll say PLEEEEEAAAASSSSE!
Old Jun 30, 2003 | 12:46 AM
Nevada's Avatar
Re:waste gate
[quote author=phox_mulder link=board=20;threadid=16265;start=0#154306 date=1056767559]Don't the 03's come with the same HY35 that my '02 auto tranny CTD comes with?<br>[/quote]<br><br>Yes they do. Both SO and HO versions have the same one.<br><br>Can't help with the wastegate question, but would be interested in the answer.<br><br>Anyone?
Old Jun 30, 2003 | 10:05 AM
parshal's Avatar
Re:waste gate
You may try calling Edge and seeing if you can get their boost elbow. It takes all of 5 minutes to remove and install. My wastegate would open at 22 psi and 22.25 psi with the EZ and no boost elbow. With the boost elbow and EZ I get 32 psi sometimes.<br><br>Please note, I removed my EZ once and left the boost elbow on and it threw an overboost code. I would suspect by adjusting the wastegate you're going to eventually get an overboost code if you're not manipulating the fuel somehow.
Old Jun 30, 2003 | 05:27 PM
03dodgeram's Avatar
Re:waste gate
the wastegate is the little silver canister on the engine side of the turbo with a rod coming out of it. i just took the clip off the rod and unbolted the wastegate acctuator and put washers between it and the turbo and bolted it back on. its vary simple. ive also found out you wont throw and over boost code till you hit 30psi
Old Jun 30, 2003 | 10:24 PM
Re:waste gate
Perfect, thanks!<br><br>Will look and try <br><br>Monte
Old Jun 30, 2003 | 10:44 PM
misterKTM's Avatar
Re:waste gate
I'm getting about 37-38 lbs of boost with EZ and the boost elbow installed.
Old Jul 1, 2003 | 08:35 AM
parshal's Avatar
Re:waste gate
[quote author=misterKTM link=board=20;threadid=16265;start=0#155271 date=1057031052]<br>I'm getting about 37-38 lbs of boost with EZ and the boost elbow installed.<br>[/quote]<br><br>HO's are getting more boost than the SO's.
Old Jul 1, 2003 | 04:04 PM
03dodgeram's Avatar
Re:waste gate
mine is an ho. what exactly is the boost elbow and what does it do?
Old Jul 2, 2003 | 09:48 AM
parshal's Avatar
Re:waste gate
It's a little brass elbow that you remove from the turbo (it has a rubber hose connected to it) and replace with this new elbow. It has a smaller hole and will allow the turbo to spool up higher.
Old Jul 2, 2003 | 10:47 AM
Copenhagenjunkie's Avatar
Re:waste gate
I found this nice pic of a cutout from an 03 turbo.
ox
Apr 27, 2003 12:26 PM
powerplant2
Feb 14, 2003 04:36 PM
whiteknight
17
Jan 8, 2003 10:38 PM
ox
Jan 8, 2003 08:41 PM
