Do i need to adjust waste gate after installed EZ?d
Old Jan 6, 2003 | 01:16 PM
whiteknight's Avatar
Im getting 25 psi boost w.o.t should it be more or not? if so what to do? will more boost help it run better without getting too lean or is it fine? soorry for all dumb questions to you gooroos :
Old Jan 6, 2003 | 02:54 PM
Hired Gun's Avatar
Re:Do i need to adjust waste gate after installed EZ?d
I just put a Power Max 3 and am getting 30 or so on mine its a 99. No problems yet.
Old Jan 6, 2003 | 05:16 PM
chuck3's Avatar
Did you put in a different boost elbow whiteknight?
Old Jan 6, 2003 | 10:20 PM
Hey chuck thanks for the message,i did change the elbo with the one that came with EZ.is there an orfice # on them or how can a guy tell which one i should get? the hole was pretty small on the one i put on.
Old Jan 7, 2003 | 12:22 AM
BigBlue's Avatar
I get 30 psi out of mine. But then again, I used the turnbuckle method so I can adjust mine. I don't know if it will really help you any performance wise. If you have black smoke at full boost, then yes, more boost will help performance. If you only have a slight haze, then no, it won't help much, if any. I don't think you can really run it to lean. I could be wrong though. Just watch your EGT gauge. If the temps get to high, back off the boost a little. At least, I'd think that if your running to lean, the temps would be to hot.
Old Jan 7, 2003 | 08:07 AM
thanks big blue, i guess maybe im alright then, i get a small cloud when i shift but thats it as far as smoke.
Old Jan 7, 2003 | 10:33 AM
BigBlue's Avatar
Sounds bout right.
Old Jan 7, 2003 | 03:38 PM
Fishin2Deep4U's Avatar
Don't worry about running it lean. You can't get it too lean. Basically, after you let off the accerator, you lean out the engine and it slows. What you have to worry about is running rich. This will cause high heat and worse! This is what smoke comes from. <br><br>Remember, gassers are way different than your beast! If you add more fuel, you may need more turbo boost. If you add lots of fuel, you need twins!<br><br>See, clear as mud!<br><br>Dave
Old Jan 7, 2003 | 04:51 PM
fish2 deep thanks for that post, how much boost will truck take without spinning hx35 too pieces ?
Old Jan 7, 2003 | 05:39 PM
chuck3's Avatar
[quote author=whiteknight link=board=4;threadid=9272;start=0#89229 date=1041913219]<br>Hey chuck thanks for the message,i did change the elbo with the one that came with EZ.is there an orfice # on them or how can a guy tell which one i should get? the hole was pretty small on the one i put on. <br>[/quote] <br><br> I don't remember what size it was but the second one was so small you could maybe get a straight pin in it. <br> I have heard of guys getting 45 psi out of theirs but I would not want to try it.
Old Jan 7, 2003 | 10:07 PM
i here that thanks ;D ;D
Old Jan 8, 2003 | 10:46 AM
BigBlue's Avatar
I think 35-40 psi is max on the HX35.
Old Jan 8, 2003 | 02:58 PM
StakeMan's Avatar
Pushing a turbo to far out of its map just creates more heat. I wouldn't take an HX35 beyond 35 psi. I was getting 32 psi out of the HY35-9cm. When I removed it I found a large crack in the exhaust housing around the wastegate port.
Old Jan 8, 2003 | 03:59 PM
For a stock HX35, I have heard that mid 30's is max. Nor a Piers 35, well that's just a different story!<br><br>Unless you have lots of smoke or high EGTs, you should have plenty of boost. <br><br>Now don't quote me on this, but I remember someone saying that the engine typically requires about 10psi per horsepower. Maybe someone more enlightened on the turbo front can answer that question.<br><br>Dave
Old Jan 8, 2003 | 05:20 PM
chuck3's Avatar
[quote author=Fishin2Deep4U <br>Now don't quote me on this, but I remember someone saying that the engine typically requires about 10psi per horsepower. Maybe someone more enlightened on the turbo front can answer that question.<br><br>Dave<br>
<br><br> Sorry Dave I know you said don't quote me but, 10 psi per HP means at 32 psi I'm only 32 hp, bummer I though I was over 300 hp. Just kidding ya. ;D ;D
