Valve adjustment
Old Jan 13, 2015 | 03:42 PM
Reelay's Avatar
Valve adjustment
Going to adjust my valves real soon, the engine is a 24 valve. Since it is 24 valves 4 valves per cyclinder is there 4 rockers to adjust. Haven't ever adjusted these before. Probably a dumb question but I need to know what I am looking at. Thanks
Old Jan 13, 2015 | 03:59 PM
iah145ca's Avatar
There is only two rockers per cylinder. There is a bridge that the rocker pushes on to actuate both intake valves and a another to actuate the exhaust valves.
Old Jan 13, 2015 | 05:44 PM
Reelay's Avatar
Thank you make my job less confusing.
Old Jan 14, 2015 | 03:11 PM
carl48's Avatar
on your valve cover it states 0.010 and 0.026 for valve lash cummins wants it 0.010 and 0.020. it is a complex explain why chrysler wants 0.026. just adjust to 0.020 like cummins wants.
Old Jan 14, 2015 | 06:52 PM
madhat's Avatar
Administrator/Jarhead
If you don't have a barring tool, I recommend it. I've done it recently, and it's an easy day. You should have an inch pound torque wrench at a minimum.
If you have questions, PM me.
Old Jan 14, 2015 | 08:59 PM
Reelay's Avatar
Carl48, Thanks for the input from all. I have almost completed the job, had to leave on a "Call Out" for a lost person in the mountains, good out come. Anyway I set the exhaust at .026 got your reply a little too late. Just got #6 to go. Think I should go and reset the exhaust to .020? I did find several loose valves more were exhaust than intake. Tomorrow I'll finish up too late tonight. I only had to remove the valve cover I guess early models had two covers as I saw on a different web site.
Madhat, I used the bolts that hold on the pully, there are 4, 15mm bolts that work good for turning the engine over just go slow and I let the compression release. I do have a torque wrench that is in inch increments but did a little math to figure out the lbs.
Old Jan 15, 2015 | 06:39 AM
madhat's Avatar
Good deal.
Old Jan 15, 2015 | 09:39 AM
Reelay's Avatar
Carl, I think I will reset all my valves at the specs you stated, even the ones I didn't adjust. Would this be ok? When done all intakes will be .010 and exhaust will be .020.
Any input from other owners would be appreciated.
Thanks
Old Jan 15, 2015 | 12:07 PM
madhat's Avatar
That's what I set mine to, it sounded like a brand new motor.
Old Jan 15, 2015 | 02:13 PM
Reelay's Avatar
Just got done awhile ago and started her up alot more quieter.
Hey thanks for the reply, have a good one!
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
