Valve Adjustment?
Old Nov 10, 2009 | 12:16 PM
Brendan's Avatar
Valve Adjustment?
My buddy just picked up an 04 with very ypoor injectors (won't start...), he has ordered new ones and while he is in there he wants to adjust the valves. I didn't know you still had to do that on the newer ones... anyway, I said I would have a look and see what they need to be adjusted to, does anybody have those clearances handy? thanks ahead.
Old Nov 10, 2009 | 03:21 PM
Spooler's Avatar
He's gonna have to adjust them anyway when he puts the rockers back on after the injector install.
Old Nov 10, 2009 | 04:21 PM
cumminshakesit's Avatar
X's 2, i think the clearances are in the book. i just did mine called the shop to get the numbers. minus the injector install... not to bad. the back two cylinders are kinduva b!tch. i think a valve lash is recommended every 60k??
Old Nov 10, 2009 | 07:12 PM
Spooler's Avatar
No, it is recommended ever 150K.
Old Nov 10, 2009 | 07:16 PM
krh's Avatar
krh
10 thou intake, 20 thou exhaust. dont forget to be careful with those injector crossover tubes
Old Nov 11, 2009 | 08:16 AM
XLR8R's Avatar
Post-R&R lash adjustment is recommended, but not required if you make sure all the bits & pieces go back where they came from... we do it just to get a little more action out of the cam.
Old Nov 11, 2009 | 09:59 AM
brianhanna's Avatar
On an 04, I think recommended service is at 100K but I did mine at 65K and found they were getting close to max lash, esp on the intakes. IIRC the manual says you can have .015 on the intakes and mine were all at .013 or .014. Exhausts can be .035 and I had .028 to .030. Anyway, I went ahead and adjusted them all to .010/.020. It gave me a small improvement in mileage (maybe .5 MPG) so as long as you're in there, I'd say go ahead and do it.
Old Nov 11, 2009 | 11:05 AM
dieselfreak21's Avatar
It should be on the engine indentification tag on the valve cover as well. It is on my 03 any way.
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
