update on 5.9 carboned up/inj. sticking
Old Mar 20, 2008 | 11:09 AM
snyyyper's Avatar
Well after 2 dealerships my truck is finally fixed. I posted a couple of weeks ago on here about how my 2007 w/ 5.9 cummins was cutting out and surging with 22K miles on the clock. Dealer #1 said it was my fault for not working the truck hard enough, said the motor was carboned up, charged me $142.00 to flush injectors and sent me on my way. couple of days later problem came back, took to dealer #2, after 30 minutes they said the truck was ready to go. The fuel pressure sensor was bad. They said the fuel pressure was so high it was forcing fuel past the valves in the injectors. truck seems to be fine now. I would go back to dealer #1 and demand a refund, EXCEPT for the fact that my truck is now getting 2 mpg better. I will now use lucas with every fill up.
Thanks,
Scott
Old Mar 20, 2008 | 11:11 AM
sootindiesel's Avatar
thats good to hear i'm glad you got everything worked out, and to boot getting better fuel mileage.
Old Mar 20, 2008 | 12:10 PM
nvr-enuf's Avatar
Are you saying lucas has something to do with mpg? I am missing the point.
Wouldn't your mpg be increased as a result of correct fuel pressure?
Old Mar 20, 2008 | 12:58 PM
LongRanger's Avatar
I would still try to get my money back. BS is BS. Of course, I could understand if it is worth $142 to you not to have to deal with theiving lying idiots.
Old Mar 20, 2008 | 01:18 PM
snyyyper's Avatar
no, my mpg increased immediately after the injector flush. I will use lucas to keep things clean now.
Old Mar 20, 2008 | 01:35 PM
tauberson's Avatar
What year is your truck and what kinda mpg are you now seeing?
Old Mar 20, 2008 | 01:38 PM
snyyyper's Avatar
2007 5.9 quad cab 4X4 3.73 gears, was getting 17 mpg now getting 19.2 (hand calculated)
Old Mar 20, 2008 | 02:11 PM
DBLR's Avatar
I don't think you need to use Lucas in every tank to keep the injectors clean. I use it and found I can get by only using it every 3rd tank of fuel. That is unless you only drive it in town or don't work the engine hard at all.
JMHO
Old Mar 22, 2008 | 09:50 AM
NickBeek's Avatar
What did they replace, the rail pressure sensor?
Old Mar 22, 2008 | 10:02 AM
06RAM2500's Avatar
Sounds like it didn't throw any codes. Or did it?
snyyyper
21
Mar 15, 2008 10:27 AM
gunracer1
Jun 14, 2007 07:18 PM
9 sec camaro
20
Aug 26, 2006 01:30 PM
BoostdCTD
Jan 15, 2005 06:29 PM
MnTom
Aug 25, 2004 11:19 PM
