sticking in 5th
Old Feb 1, 2003 | 08:06 AM
gunracer1's Avatar
sticking in 5th
i finially got a 2nd gen truck, i have been holding out for a long time waiting on the right deal. i got a 97 dually 4x4. the truck sticks in 5th gear, not bad but it doesn't feel normal. i have to push the stick forward to get it to release. i know my uncle replaced his tranny when his kept sticking in 5th. any ideas? i was going to change the fluid this week and put in some mobile 1 in the tranny and the diffs. and see if that seems to help the problem. just hopeing for a cheap fix.mike
Old Feb 1, 2003 | 10:54 AM
97Dually's Avatar
Re:sticking in 5th
Gunracer,<br><br>Pretty truck! <br>I have the exactly the same issue with mine too. I will drive for a while in 5TH and eventually when I downshift i have to pull with a considerable amout of force to come out of 5th. I don't feel the symptom in any other gear though. At first I wasn't sure if i was depressing the clutch in far enough, but further investigation proved that that was not the problem. I too am curious as to the cause.... ???
Old Jun 13, 2007 | 03:09 PM
gibson66's Avatar
I know this is a old post but i was wondering if anyone knows where i can get pictures or illustrations of what is talked about in this post. I have a 98 that is stuck in 5th and i need to figure this out. What would be the best mauel for these trucks also. Thanks
Old Jun 13, 2007 | 03:46 PM
DennisT's Avatar
photos?
I must have missed the photos...or I cannot find the attachments.
Good info though,
Dennis
Old Jun 13, 2007 | 08:12 PM
infidel's Avatar
I've run into this on three trucks, the cause was all the same, the end of the shifter was worn out and allowed 5th and another gear, not sure which one, to partially engage at the same time. Don't have a picture but if you take the top of the tranny off from inside the cab you'll see right away what's wrong. Prying with screwdriver will fix it and it will stay fixed if you shift carefully. If you want to fix it permanently it's a little more involved as the shifter isn't availible separately anymore, you'll have to hit a junkyard.
Old Jun 14, 2007 | 09:35 AM
gibson66's Avatar
I took off the shifter and my problem seems a little different than yours. With a screwdriver i can put it in all the gears fine, but it will not come out of 5th. 5th has a arm that goes down towards the drivers side of the tranny and actuates a rod. If we pry up on that arm it will come out of gear. Any ideas? Next we will probablly pull of the rear of the tranny to see were all this goes and see what is binding it.
Old Jun 14, 2007 | 07:18 PM
infidel's Avatar
Call Standard Transmission & Gear 800-783-8726 and explain your problem.
These guys are sharp and will tell you right away what could be wrong and how to fix it.
LemonDodge
Sep 7, 2019 03:51 PM
LemonDodge
Sep 16, 2010 07:33 AM
SeanB23
Apr 16, 2010 06:20 AM
PapaSmurf
Sep 25, 2003 09:32 PM
dsljunkie
Feb 17, 2003 03:37 PM
