unknown vibe?
Old Mar 6, 2005 | 01:06 PM
The Domie's Avatar
unknown vibe?
I have noticed an annoying vibe as I come up through 67 mph under power.
I coasted the truck down a long hill in neutral going between 65 and 70 mph and there was no vibe.
Is this the same drivetrain vibe I keep reading about or something different?
Seems that the ones I read about are all the time, at that speed, not just under power?
The Domie
Old Mar 6, 2005 | 01:35 PM
Hannibal's Avatar
Nope. That's normal engine buzz. I wish that's all my '03 had.
Old Mar 14, 2005 | 09:20 PM
derekleslie's Avatar
moving this to the front.
Old Mar 15, 2005 | 08:29 PM
Dodgezilla's Avatar
I rotated my tires a couple of weeks ago. This was the first time that I actually did the "Modified X" instead of just switching fronts to rears and vice-versa. Immediately I got a vibration at 70 mph that I never had before. I switched the two front tires around and the vibration stopped. Go figure.......
Old Mar 16, 2005 | 05:10 PM
eastmentCTD600's Avatar
I've got that vibe, underpower from approx 55 - 70 MPH especially if it locks up in OD.
I believe it has to do with the rear carrier bearing and position/angle of the u-joints. I had the TSB for shudder on take off done, well that was cured but the vibe moved to that 55 - 70 MPH range now.
I'm going to look into a custom solution for the driveshaft because I know any dealer I go to will be incapable of fixing and/or diagnosing this issue. It's not terrible but it is noticeable.
Eric
97RAM
Nov 30, 2004 03:57 PM
NJMurvin
39
Nov 25, 2004 05:26 PM
Nolynn3
Sep 18, 2004 09:25 PM
3rd_ram
18
Sep 8, 2004 02:19 PM
MoreSmoke
Feb 4, 2004 09:19 AM
